It turns on fine but it doesnt accelerat
SOURCE: 1994 ford explorer
Sounds like the governor valve is sticking. The governor is on the output shaft. If this is a 4x4, the transfer case has to be removed to get to it. If it's a 2wd, the extension housing has to be removed to get to it. The valve is located in the governor body. It's aluminum & is bolted to the collector. You'll have to unbolt the gov body & clean it in solvent to make sure the valve moves freely in it's bore.
SOURCE: Ford e 350 No power when i press gas petal.
my car did this. two things that i know of can do this.
#1. fuel injectors getting corroded.
#2. bad alternator/battery
SOURCE: My 1992 ford explore tries to quit when i
restricted exhaust can caused low power on accell.
SOURCE: My 99 ford explorer cuts out and dies when accelerating in drive
You may have dirty or clogged fuel injectors, may also be problems with the ignition system. Might also check the fuel pressure to make sure the fuel pump is working correctly.
Check the sensor in your ******. most likely the only thing left. be sure to check the harness at your cluster for voltage to eliminate wiring or fuse faults.
Can it be the position sensor?
