Vehicle Parts & Accessories Logo
johnny sanchez Posted on Jan 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the color codes to this plug? - Vehicle Parts & Accessories
Sudeep Chatterjee
Level 3:
  • Master 3,267 Answers
  • Posted on Jan 26, 2013
Sudeep Chatterjee
Master
Level 3:
Answers
3267
Questions
10
Helped
1159114
Points
10260
Black = AC hot
Red = switched AC hot
Yellow = AC hot from a another source - another control panel as an example.
White = neutral
red w/white tracer = switched neutral
Green or green w/ yellow tracer = ground/earth ground
blue = DC voltage, ie, 12vdc, 24vdc
white w/blue tracer = dc common
What is the color code for the 2 plugs on the instrument cluster?
Color codes may not be exact, but the pin outs are. Telling you what wires goes to where. 24225256-tijdub2y0h3m0vcaz2bqtnkd-3-0.gif 24225256-tijdub2y0h3m0vcaz2bqtnkd-3-2.gif
I cant get a stereo hooked up
Your question is not very specific but I expect that you have discovered that Volvo does not bother to color code their sound system wiring. They seem to use whatever wire they have laying around, so there is no particular pattern, and often all the wires are the same color.
If your car still has the original stereo plugs, you can buy a wiring kit from the installation shop at Best Buy. It will have a plug that plugs into the Volvo plug and wires that are color coded to standard color coding so you can figure out how to connect it to the new stereo. I not only had to put in a new stereo, but I had to bypass the original amplifier in my '91. The kit from Best Buy made it all Plug and Play!
Hot and neutral wiring not color-coded on plug, three prong. Green is color coded.
1,brown/red is live to right.2,blue/black left.3 green is top of plug its earth .good luck.adrian,,
Color coded travel adaptor. Not sure color matching Germany
Don't know the color codes, but It has two 4.8mm round contacts on 19mm centres and two grounding clips on the sides of the connector body for Germany (Type C Plug).
1helpful
Wire color code to what number plug post
Red and sheid 1
white 2
blue 3
black 4
95 lumina with cut cables on the tranny plug
I don't have a diagram so am just going to advise you to clean the wires and see if they are color coded, if they are you just have to connect color to color and since it is a car, they probably are. If you end up with a several same color wires and the others are coded, the same color ones probably connect to the same place electrically and can be connected to any the same color.
You can also look very carefully at the ends of the wires and possibly pick out the ones that go together.
Good Luck.
11helpful
Looking for color code (diagram) - 7 wire trailer harness/wiring
If you haven't purchased the plugs yet. The wire color codes should be included in the package.
  • If you are using used plugs ck the back of the plugs for color or function of wire
  • Wht - ground
  • red - stop
  • blue - accessory/aux
  • brown - tail
  • black - Marker
  • grn - left turn
  • yellow - right turn
Need color code for 96 aerostar van
if the plug ends are the same it should work and you may have to take a plug from the aerostar and use that plug on the windstar
1helpful
Amana dryer, changing out the electrical plug from 3 to 4 prong
For example; Green wire goes to green screw on machine. White in the middle, red on left, black on right. (observed small color coded wires connecting in back-ground as well.)
In general, each color should match. Meaning, white with white.
Jan 27, 2009 • Dryers
4helpful
2answers
Stereo wireing color codes for 2004 suzuki forenza
you are a ******* idiot you+this answer= you are ******* stupid we don't want to know what our best bet is you damn inbred **** we want color codes!!!!! God you are dumb what color means what its like putting the caps back on the right markers in your coloring box with your little books that you cant even color inside the lines cause you are so stupid!!!!!!
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
