A
Anonymous Posted on Jan 25, 2013
Got a panasonic compact audio system model # SG-HM09A the turntable plays the record fast
The turntable runs the speed but the the song that you play, plays fast
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 21, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
720
Points
0
There should be a small switch on the inside of the turn table that allows you to switch from 45 (what i think your listening to) to the normal speed which i think is 33
5 Related Answers
Jma11
John
  • 140 Answers
  • Posted on Nov 29, 2008
SOURCE: LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Anonymous
  • 515 Answers
  • Posted on Aug 08, 2008
SOURCE: JVC AL-E300 Turntable
More than likely your motor might be bad. There is nothing else that controls the speed. Are you sure you purchased the correct size belt? Turn on the unit, without connecting the belt, and touch the motor shaft, and see if it fluctuates. You can also just get a marker, and marker a point on the motor shaft. When you turn it on, it will act as a visual indication as to it's speed.
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Anonymous
  • 42 Answers
  • Posted on Jan 25, 2009
SOURCE: turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Anonymous
  • Posted on Feb 02, 2009
SOURCE: Sony PS-LX250H speed problem
I have a different Sony model (PS-LX-150H) that had a similar problem. I hadn't used it in awhile, and then when I did, I noticed the speed problem.
IF your PS-LX250 is like my PS-LX150, there are small speed adjustment screws accessible from the bottom of the unit. On mine, the two adjustment screws were labeled - one for 33rpm, the other for 45 rpm. Basically I just fiddled a bit with them using a very small precision screw driver until I could verify that I had reached 33 rpm (I used a stopwatch and literally counted the number of rotations/minute after making adjustments.)
Now it sounds right!
mydogisk
Kenneth
  • 50 Answers
  • Posted on Apr 10, 2009
SOURCE: crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
How do you slow down the turntable
You most likely have a bad capacitor in the motor control circuit.
Kaito ka1916 turntable operates at very low speeds
The turntable motor is bad or the B+ is to low
AFTER adjusting the speed setting to 33, all the records are playing too fast, they sound like chipmunks. I tried all three settings and while each speed is different from each other they all seem to be...
If it says your speed setting in on 33, than you have a problem with the speed control inside of the turntable, there is not much you can do in that area. 33 is the slowest speed too, so it seems like it is stuck on 45 or 78. Call Teac if you are still under warranty.
2helpful
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Is it possible to connect my panasonic sg-hm22 to my Denon Reciev
You need an "Audio Output" ie. Tape 2 mon or Rec out (RCA jack) on the Panasonic for it to work. Hope this helps
Rca record player is playing slowed down or sped up
Hi there
this sounds like the belt that drives the turntable itself is slipping you can normally access it by removing the securing clip by the centre spindle and then lift the turntable up and you should be able to see the belt give the belt a good clean with isopropyl alcohol refit and hey presto (if you still get slippage order a replacement belt )
Rgards Al "Alstech "
2answers
PANASONIC COMPACT AUDIO SYSTEM SG-HM22 good value @ $75???
You can't put a price to something you have no idea what is all about. Know the condition of the unit, if it does work, it's a steal for used one.
Turntable speed
There is no pitch control on this unit.
3answers
PANASONIC COMPACT AUDIO SYSTEM MODEL #SG-HM22 help
some models have a hole(s) in the turntable under the mat. You can put your fingers through the holes in the turntable to fix the belt into position. Good Luck.
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
