Computers & Internet Logo
Posted on Jan 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer crash and restart - Computers & Internet
Anonymous
Level 3:
Genius:
  • Master 1,124 Answers
  • Posted on Jan 28, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1124
Questions
0
Helped
364672
Points
3197
Windows restarts without warning
Cause:
This issue could be caused by any of the below possibilities.
Software issue or error.
Hardware issue or error.
Heat related issue.
Computer virus.
Issue with operating system.
Answer:
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing.
If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode.
If the computer is still rebooting in Safe Mode the issue is likely not software related but something else, skip to the next section. If the computer is not rebooting in Safe Mode it is likely you have software related issue. We would recommend you run through the basic troubleshooting section for your operating system.
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD. Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
From the desktop right-click on My Computer.
Click the Properties option.
In the System Properties window click the Advanced tab.
In Advanced click the Settings button under Startup and Recovery.
In the Startup and Recovery window uncheck the Automatically restart check box.
Click Ok.
Now if the computer generates and error it should not automatically restart and enable you to display any errors your computer may be experiencing.
Any failing hardware component in your computer could cause your computer to unexpectedly generate an error and/or reboot without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers.
If you have updated drivers and removed any hardware that could be causing this issue and continue to experience random reboots, it's possible that the memory is bad in the computer.
Finally, hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
Computer virus
Computer viruses such as the blaster virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus make sure your virus scanner definitions are up to date.
Heat related issue
Many computer today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets to hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer you will need to either open the computer and make sure the fan are working (processor fan and case fan) and/or if your BIOS monitors the RPM of the fans enter BIOS and make sure the BIOS does not report any errors.
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
Reboot the computer and enter CMOS setup as the computer is booting.
After you have loaded the computer in CMOS setup let the computer sit.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1191
Points
Sir i got a problem in my computer, my windows did not start successfully
  • Anonymous Apr 09, 2009
    but i cant get into cmos setup
    we start windows it will automatically go to power saving mode
Reiniciar el equipo
Normal restart: select restart from the apple menu, or press the power key (the sleep/restart/shutdown dialog appears), then click the restart button or press the "r" key.
Forced restart (use only if the computer crashes or freezes): Press simultaneously the Apple, Control and power keys.
Forced shutdown (use only if the computer won't respond to anything, not even a forced restart): Press and hold the power button on the computer until the computer shuts off.
Shock wave crashes
Uninstall shock wave and restart the computer, also! uninstall chrome and restart the computer for changes to take effect, now re-install chrome to see if it will work, no issues! try shockwave again, if problem returns get rid of shockwave or choose another browser.
My n computing terminal server windows 2003 is getting restarted , i have connected around 15 users please help me to solve this problem.
It is getting restarted on it's own? If so, it sounds like you have a driver conflict and you've setup your system to simply restart when there is a crash. Enable the crash dump to capture the Blue Screen information the next time the server restarts. Please provide the version of vSpace you're using.
2helpful
2answers
Im not getting *** videos
1.Watch videos at off peak times, if possible 2.Do not run other programs while watching videos. They slow down computer ingeneral by making use of memory. 3.Add RAM on your computer. More RAM will make easy execution of heavy programson your system. 4.Get better and speedy internet connection. Talk to your ISP in this regard. 5.Regularly clean windows registry. Windows registry is vital place that storesinformation for important computing functions. A congested or corrupted windowsregistry makes computer slow that causes YouTube like freezes. For this, getthe best registry cleaner RegInOut cleaner and optimizer. Use it once in afortnight for fast computing to avoid YouTube freezes and system slow down.
I had a btand new 2011 quickbooks running on my computer then after a week it crashed. I can't open it and it gives me many error messages when I try to reinstall it. I have a 64-bit computer that has...
Hi there !
For some reasons computer can crashed because some corrupted, missing files, virus program or faulty driver installed. Faulty installed drivers or multiple drivers installed with the same drivers can crashed your computer. Running on Safe mode will remove mulltiple same drivers in your computer and it will run on fresh install driver when loading to normal mode.
I suggest to run your computer on safe mode.
To run on safe mode, just restart your computer and press F8 to run on safe mode. After going to windows setting, restart your computer again. Check if this solve your problem.
I hope it helps you and thank you for using FixYa!
My computer does not read my external drive (WD MyBook 250 GB). My work computer will not recognize either. It was working fine, but a Firefox crash necessitated a computer restart. After the restart, the...
You don't say which version of Operating system you are using. My thoughts are to first go to "my computer" and see if your drive shows up there. If not, get to disk management and see if it shows up there. The crash possibly could have messed up your external drive, and now it needs to be initialized and/or formatted.
1helpful
Display driver crashes & recovers. Sometimes over and over again until computer crashes. Then I have choice of safe mode, normal etc.
restart computer at startup press f8 down for 3 secs / should give u options /go to safe mode hit it follow on sceen till u get to desk top open controll go to uninstall programs open and find the driver u put on should be display and deleat then restart should solve dave if not f8 restart try f11
Emachine W6409 will no longer turn on
Your hard drive is probably crashing or has crashed. You need to start your computer with an XP CD and try to use the repair function. You'll be able to tell if the hard drive is still working or not once you run the repair function. Let me know what happens or if you run into any problems.
Blue tooth headset problems with vista
all vista software goes of the market on the 11th april 2017 and it wont be avaible to restall it any more as microsoft wont allow this to happen ,,,,,,,,,sorry as i have vista and i will loose so much of my computer too on that day
Grand Canyon Tech
Grand Canyon Tech
