Sanyo PLC XU48 Multimedia Projector Logo
Posted on Jan 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Sanyo PLC xu48 keeps turning off after 10 mins and then
Once it cools I can restart it. this is very recent but I did buy an OEM bulb...could it be that it is overheating?? Thanks
Stefanos
Anonymous
Level 3:
Genius:
  • Master 2,920 Answers
  • Posted on Jan 28, 2009
Anonymous
Master
Level 3:
Genius:
Answers
2920
Questions
0
Helped
934888
Points
7574
Yes your cooling fan isnt working...it has to be working to keep the system cool also you might clean the filter on it when you change the fan out
Anonymous
Level 3:
President:
  • Master 1,214 Answers
Anonymous
Master
Level 3:
President:
Answers
1214
Questions
0
Helped
566183
Points
3697
Yes, it's probably overheating, or you do not have a signal feeding it.
If overheating, check that the fan is running and any air ports are not blocked.
If it's signal, make sure the device your using to feed it signal is in fact providing a signal, and you have the projector looking to the right input port.
Anonymous
Level 3:
  • Master 10,594 Answers
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957285
Points
33084
If its aftermarket or non Sanyo lamp, that can be cause of over heating.
  • Anonymous Jan 28, 2009
    Please also check fans are ruining properly.
1helpful
How do I replace the ballast on my Sanyo PLC XU48? Where do I get a replacement ballast?
Link
Kindly try above link to know where you purchase various Sanyo parts for your projector.
Thank you.
4helpful
Sanyo PLC XU48 Need to know the lamp hours!
press and hold down the power button for about 20 seconds. The info will show in the top right of the screen.
Micketec
1helpful
Thought the bulb was bad, replaced and still no light.
where did you get the lamp from? if you got it from a reputable dealer, then i'd say the ballast is bad and needs replacing. if you got it from "bob's bulbs", then it may be the lamp. but the only way to test it is to put it in a known good projector.
Lamp goes out after 10-15 seconds
Recently had a similar issue.
When I took the lamp out (Let it cool for awhile first), there was dust all over one side preventing air from the fans from cooling the lamp, so it shut itself off after getting too hot.
I have a Sanyo PLC xu38 projector broken receptical.
you should find a new db15 female connector, and install on to pcb, this required good knowledge of soldering...
Sanyo PLC XU48 problem starting
Service and reinstall main PCB connectors and cables including sensors. check the lamp condition also.
Viren
Top Sanyo Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Rob Hill
Rob Hill
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
