The drop down in smarthru 4 will not show my 3170 printer
Forget SmarThru. Download Samsung Universal Printer Driver 3. It must be version 3. Install that, make it your default printer and delete any other supposed Samsung printer drivers. When you go to Scan, the program should automatically download Samsung's Document Creator and this will work your fax simply and easily. Anyway, it works for me.
Your machine offers the following ways to scan an image:
• From TWAIN-compliant software: You can use other
software including Adobe Photoshop Deluxe and Adobe
Photoshop.
• From the Windows images Acquisition (WIA) driver: Your
machine supports the WIA driver for scanning images.
• From the Samsung SmarThru software: Launch Samsung
SmarThru and open Scan To to begin scanning.
NOTE: To scan with your machine, you must install the
software.
Loading document
You can use the document glass to load an original document
for copying and scanning.
1 Lift and open the document cover.
2 Place the document face down on the document glass
and align it with the registration guide at the top left
corner of the glass.
3 Close the document cover. Be careful not to move the
document.
NOTES:
• Leaving the document cover open while copying may affect
copy quality and toner consumption.
So, basically, if you have the software installed. Open the Smarthru software, load your original onto the glass, face down, and close the lid. Select scan, the software may provide you with a preview of the scanned image. Once you scan the document, you must save it to a location on your hard drive, often it is called "My Scans" in your "my documents" file.
I hope that this is helpful. I have attached a link directly to the Samsung website manual for your model
http://downloadcenter.samsung.com/content/UM/200912/20091211171126218/Guide_EN.pdf
