Hello Rick, to be able to activate the recording button, you must have placed a cassette, that has the lock to record, this is in the upper part of the cassette and has one for each side, in your case it will have to have the corresponding to the on the side that you use to record
Looking at the cassette in front, with the tape down, the lock is up on the left, if you do not have it, you can replace it with a Scotch tape covering the hole
I hope my comment will serve you
Greetings Franco Dosil
Hola Rick, para poder accionar el boton de grabacion, debes tener colocado un cassette, que tenga la traba para grabar, esta se encuentra en la parte superior del cassette y tiene una para cada lado, en tu caso tendra que tener la correspondiente a la del lado que usas para grabar
mirando el cassette de frente, con la cinta para abajo la traba esta arriba a la izquierda, si no la tuviera, la puedes reemplazar con una cinta Scotch cubriendo el agujero
Espero que te sirva mi comentario
Saludos Franco Dosil
https://upload.wikimedia.org/wikipedia/commons/thumb/0/05/Cassette_Write_Protect_IV.jpg/220px-Cassette_Write_Protect_IV.jpg
