Canon PowerShot S5 IS Digital Camera Logo
Kathy Seidlitz Posted on Jan 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon Powershot SLR takes fuzzy photos
How do I take pictures of children (moving around) or pictures in low light without getting fuzzy photos?
  • Anonymous Feb 16, 2009
    hi I am also facing same problem
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
165
Points
Try using the 'Sport' mode. I use this quite frequently when taking pictures in low light situations where either I want the natural light "dusk" or the flash won't reach (such as zoomed in past 15 ft). The shutter speed is set faster for fast movement, but also compensates for the low light.
Sachin
Level 2:
Novelist:
  • Expert 98 Answers
  • Posted on Feb 27, 2009
Sachin
Expert
Level 2:
Novelist:
Answers
98
Questions
Helped
43889
Points
213
Guys,
you need additional flash or brighter light to click in low lighting condition. In order to compensate for low light conditions, the shutter goes slow and therefore you get fuzzy pictures.
Another way is to click on movie(video) mode and then atleast you can see them moving around as well as while editing, you could take out some pictures from the video( though on lmuch ower resolution).
2answers
WhY photos canon A470? i have a canon powershot A470 camera and there's a problem taking photo.. whenever i take a picture, it's either fully white or have white stripes on the pictures.. i thought it
Perhaps you check the settings. If the camera is on nightshot, or manual, with a long shutter time or wilde open diafragma your pictures are all overblown, or stripes come from lights. Put the camera in automatic. The main dial on the green camera logo, and try again. If this does not work, Please let me know how the settings are on your camera. Success
2answers
How do i take indoor actions shots with the rebel xs
Indoor actions shots are tough to take because of dim lighting and fast moving subjects. With the right settings and equipment, it can increase your chances of getting that perfect shot.
The Perfect Camera Settings for Action and Sports Photography
2answers
Black fuzzy spot in pictures
Have you verified that it is in the picture and not the screen by transferring the photos to your computer?
You way have some dust or lint that got on the lens if the photos have that problem.
Just take an eyeglass cloth and spray wither eyeglass cleaner, or just a little dab of alcohol and then wipe the lens clean.
How do I set the resolution on my Canon SD850?
The instructions for changing the resolution are on page 30 of the manual.
If the pictures are fuzzy, increasing the resolution won't help. The most likely causes of fuzzy pictures are as follows
1) Focus. Check to make sure the focus is on the subject. If something else in the picture is sharp while others are not, then the camera may have focused on the wrong subject.
2) Subject motion. If moving objects are fuzzier than stationary objects then you need to use a faster shutter speed (or flash).
3) Camera motion. Just because the camera is on a tripod doesn't mean it doesn't move. One philosophy says that if a tripod is light enough to be carried then it's not sturdy enough. For a compact camera like the SD850 that likely isn't the problem. However, you can still shake the camera when you press the shutter release button. Try setting the self-timer. This allows time for the vibrations to die down before snapping the picture.
In your particular case, I think we can assume that the subject isn't moving, so #2 doesn't apply. To assure proper focus, make sure the painting is flat and perpendicular to the lens axis. If the painting is tilted relative to the camera, then different parts of it will be at different distances and the camera won't be able to keep all of it in focus.
Also, make sure the front of the lens is clean.
Fuzzy pictures
Make sure that you are not moving the camera as you take the picture. Make sure what you are taking is not moving as you taking the picture. Also, the last thing you can check for is to make sure that your flash is coming on.
5helpful
Canon PowerShot A60~~~Viewing screen black/fuzzy won't take pict.
Its known problem of ccd imager in Canon A60 camera and Canon will repair it free of cost.
Click Canon CCD Imager Advisory for details.
1helpful
2answers
Photos are fuzzy. At the time it takes 52 picts. a round. Would they be sharper if I reduce the picts?
Hello MaryRoth,
Photos are fuzzy due to many reasons and the main two reasons are that the subject is out of focus or the subject or the hand shake during the time of taking the snap.
Please make sure that you select appropriate picture modes (Macro, Portrait, Landscape etc..) when taking snaps. Make sure that when you press the click button half-a-way (known as AE mode), the subject is still in focus.
Try using a Tripod stand in case the hand is not steady or try increasing the shutter speed if its an SLR camera. That should help.
Let me know if that works.
Regards,
Srinivas
Apr 27, 2009 • Cameras
2helpful
2answers
Canon T70 not taking photos!?!? Help
Oops my bad.
It could be a jammed shutter. If you take the lens out and the film out. Take a few pictures and see if the shutter moves. If there is no movement I would take it into a camera shop and take a look at it. Unless the shutter spring is busted, it could be an easy fix.
Canon powershot a520
You probably changed a setting or were taking photos in low light. If you take a photo in the middle of the day, in full-automatic mode, is it still hazy? Maybe you got something on your lens?
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
