The washing machine makes a loud clicking (knocking) sound and the lights dim with each knock during the rinse cycle. The sound is not heard during the agitate or drain cycles. The agitate and drain cycles operate properly. I have already changed the motor coupler, the clutch, the lid switch and the pump. There are no obstruction in the drain lines.
Possible that the bearings are a suspect, if the machine seems to wobble around. Also if the load is high, does the noise go higher, if so check the suspension, check the mounting and the counter weights.
Please check this link: Wobbling machine
SOURCE: Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
SOURCE: washing machine - knocking sound at end of cycles
actually by the sounds of it, you have a top loader. simply apply a small portion of grease to the brake drum and this will take the severity off when stopping. if you dont do this incidently, eventually your coupling will break.
SOURCE: Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
SOURCE: making loud knocking/clunking sound in the wash cycle.
i have the same problem. the transmission/brake assembly is worn out. the stopping and starting problem... I have that too, that was a dry solder joint on the circuit board. i found it because if I pressed on the area of the panel to the left of the cycle select knob, it would shut off immediately. I soldered it back up and it's fine. Still working on fixing the transmission problem, the parts store wants 300 bucks for the part but looking at the GE website, the tranny might be under extended warranty.
SOURCE: Knocking noise during agitation cycle - GE WNSR2100T8WW
I believe you must have one of the bottom of the line cheapo washers, as I do--the one with the plastic, rather than steel wash tub and basket? These are pretty poor machines. They cut corners drastically in every part of the design. I've replaced the aluminum hub that supports the spin basket ( the hub is bare aluminum and corrodes within about 5 years use from the highly alkaline detergent, then it fractures under mechanical stress. Then the motor burned out. I was able to get a nearly new motor on ebay for $90 incl. shipping. (BTW, if you need appliance parts try GOOD Appliance on ebay for new and salvaged parts--they're excellent! 100% feedback rating) However, I now have the same problem--a fairly loud knocking noise during the agitation phases of the cycle. This is cause by a really crappy transmission design that does not wear well. My advice is just ignore it as long as it works and isn't leaking oil and the tub seal is still good. If it does finally go to pieces get one on ebay--that is if you feel up to doing the job yourself since a repair person would charge more than it's worth to install it. I believe new ones can be had on ebay for about $80, some are sold with seal kits. Bottom line is--if you want a machine that will last you for 15-20 years--don't buy a cheapo model. The front loaders are better as they use far less hot water (energy and water savings) but a good one is going to be anywhere from about $800 to $1600.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Torex: I don't thing the heating element would cause the lights to dim with every knock... did yours do that?
The machines does not wobble and is level. Is it the tranmission? Is the transmission the same thing as the gearcase?
