Avital will crank the engine but will not start. Engine starts fine with the key
Did it ever work as far as you Know? Some vehicles have a coded key and if the key is not in the ignition at the time the remote is activated it will not start. Some systems have a key hidden in the system and some have a bypass. It is hard for me to tell you which you have as not being the installer. You may have to contact Avital or go to thier web site for more detailed info.
SOURCE: cranks but engine doesn't start avital remote start
I beleive it is a pink wire for the ignition. If you can locate where it is connected this is your ignition wire. It may have worked loose under the dash.
