Audio Technica AT-PL50 Turntable Logo
patty luker Posted on Jan 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Akai fully automatic turntables tone arm not functioning properly
Eliezer Pennywhistler
Level 2:
Champion:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 236 Answers
  • Posted on Jan 29, 2013
Expert
Level 2:
Champion:
Cheetah:
Answers
236
Questions
0
Helped
61976
Points
247
And when you tell us what it is doing and not doing we can consider a solution.
The tone-arm on my turntable automatically stops too early. Is there any way to fix this?
Yes. you need to set the travel on your arm. I don't know your specific model but they are all the same concept. On the back by the pivot point there should be a small screw that you can adjust the travel before it returns.
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
My Technics turntable slqdd22 cue and stop buttons not working
Hi, with the tone arm sitting on its mount rotate the platter manually approx. 12 times. That should reset all the auto functions. Cheers john.
Tone arm will not move over on self-start unless
Hi, they are not an auto start model turntable. To start lift tone arm off rest and move into position at start of record. It will automatically lift and return to rest as well as shut off at end of record. cheers john ,, Styluscity.com
1helpful
Tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
1helpful
Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
KD-67F fully automatic turntable--servo mechanism has suddenly stopped
I wish to help but I "NEED MORE INPUT". mgfr, model, type,ect.
Tone arm won't drop
This is a tough one. There is usually a series of gears that function in unison to make all the magic happens. These gears are usually set in motion by a smaller belt located inside the unit. If this belt has come off or is damaged, your unit will not work. Or, if the gears have cracked, or dried up, same issue.
Suggest taking it to a service center for repair.
- OPTiC
Turntable Technician
www.1200s.com
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
