Question about Kohler 14resa 14kw Home Emergency Backup Generator
Kohler 14resa is the start up time delay changable
The generator comes on every week as scheduled. When it is tested by shutting off the power it comes on fine. But if the power goes off and then back on within 10 seconds or so, the generator starts to come on and go back off and shuts off on default. I go and restart and it goes to normal. It is the short flutter off/on for a few seconds that makes the unit disconnect and need resetting. I think the start time is 1 to 3 seconds after power failure. I am thinking the start time should be maybe 10 seconds
SOURCE:
CarlGehrke
  • 169 Answers
SOURCE: kohler 12kw generator starts but shuts down after 3sec
Your gas pressure is too low and you may not have a large enough supply pipe. You need at least 10 inches of water column with the engine running to operate an LP vapor fueled engine. Because the engine is starving for fuel, its governor opens the throttle to WOT (so it goes to high revs) but there isn't any fuel to make horsepower with so the output voltage falls and the undervoltage alarm trips.
Carl
Posted on Dec 03, 2008
SOURCE: kohler lp shuts down
What you need to know is there enough fuel going to the regulator. It should be 7 to 11 inches Water Column. If not your problem may be not enough fuel. That includes when the heater in your house kicks on and what ever gas appliance you may have. Once you verify that you need to figure out if you have the proper pressure coming out of the regular on the inside of the generator. Next I would look at compression of the cylinders. It may need new piston rings.
Posted on Oct 09, 2009
SOURCE: Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Posted on May 06, 2010
consaka
  • 661 Answers
SOURCE: Kohler Model 12RES LP gas generator starts
Sounds like a short in one of the windings to me. Can you verify that the engine rpm is not exceeding specs? If you can modify the engine speed Id say slow it down and see what the voltage read is.
Posted on Jul 22, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Hello....i have several problems and
Hi and welcome to FixYa, I am Kelly.
I can not tell you how to get it out of it's current mounting position without seeing it. (Just being honest) And the wiring is different for each RV depending on what electrical system the ORIGINAL owner opted for. My experience with RV generator is that you can usually slide them out on rails just far enough to disconnect the wires. Just do yourself a HUGE favor and draw your own wiring diagram.
Number the wires 1 through 8 (
Ok.... here is the diagnostic and service manual:
http://www.kohlerpower.com/onlinecatalog/pdf/tp6196.pdf
See the troubleshooing steps on page 25 and also see sections 4-4 and 4-5 to determine why it is shutting down. First thing check the oil level! The engine has a Low Oil Level and low oil pressure Pressure Sensor. Either one will shut off fuel. Read in section 5 also....
The squalling noise your hearing is probably dry starter bearings. There is not a quick fix for this other than to disassemble the starter and lubricate it. If the bearings in fact dried out you will have to also wipe off the armature shaft area where the bearings are. If you just lubricate it without disassembly it will eventually lock up from the left over residue.
The fuel system is discussed on page 66 of the manual link. This appears to be an LPG powered unit. If it is not LPG powered find your engine number and I will get your engine service manual also so you can locate the fuel pump. (I think this is either the CH or CV740-0035 engine) If I remember correctly the fuel pump is vacuum powered on this engine if it a diesel or gas model. The diesel engine also has a fuel injection pump in addition to a fuel pump. (just depends on what sub model of the 12 RES-L you have. The L usually designates it as an LPG unit.)
The parts list is here:
http://www.kohler.com.sg/onlinecatalog/pdf/tp6399.pdf
Air Filter: (Page 17)
9 24 083 09-S Element, air filter ( or use this page to locate a Kohler dealer:
http://www.kohlerengines.com/wheretobuy/landing.htm
Thanks for choosing FixYa,
Kelly
Posted on Aug 09, 2011
Can I see a copy of order?
You need to request this from whomever you purchased the generator from.
May 31, 2015 | Kohler 14RESA Home Standby Air Cooled...
14kw kohler propane generator-sometimes does not start, put battery jumper on and it starts. Battery is new, but had the same problem with the old battery.
The battery charger is defective, as you can start it by jumping it off means it is just a low battery. without it running measure battery voltage, it should be around 12V then plug the charger back in, it should climb to around 13.8B with a good battery. If not have the float charger checked.
Jan 25, 2013 | Kohler 14resa 14kw Home Emergency Backup...
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
I have a locked rotor fault message.
I had this fault show this morning. Very alarming, as we have a typhoon coming theough tomorrow!
Turned out to be an easy fix. When I hit start the solenoid engaged but nothing moved. Then I saw the fault message and thought "Large $$$$!"
It was just a bad 12 Volt battery, and when it couldn't crank it threw the fault code. I replaced the battery, pulled the 3 fuses on the control panel (mine is the 20 Kw model), and the codes cleared, and she fired right up.
The advice here and on a couple other sites about powering down the panel to clear fault codes saved me a lot of time, money and aggravaion, not to mention a freezer full of food (knowing the Guam Power Authority, and knowing typhoons, the power WILL go down tomorrow.
Jul 27, 2012 | Kohler 14resa 14kw Home Emergency Backup...
If I lose street power momentarily and my generator immediately starts than quits because the street power comes back on, the weekly 20 minute generator excercise does not work.I have to reset the transfer...
Although A bit inconvienent this does seem to be the norm for some Kohler units. Actually a small price to pay rather than having a technician come out to replace the ATS control board. There are time delays that could be set longer to keep the unit running longer and may prevent this from happenng
Jan 03, 2011 | Kohler 18RESL 18 kW Emergency Power...
mike
Sep 24, 2009 | Kohler Electrical Supplies
My Kohler 17RES has stopped doing it's scheduled weekly exercise. How can I get it exercising again?
On your Automatic Transfer Switch ( the little gray box you see on the right in the picture above) you have two blue buttons. One is a Manual test switch. The other has a clock on it and this is your exercise set button. Hold it down for a FULL 3 seconds if you want it to excercise without a load (not powering your home) Hold it down for a FULL 6 seconds if you want it to exercise with a load every week. Your generator will start and run for 20 minutes, and then shut down. Now every week your generator will exercise at the time and day that you pushed the set button.
Aug 08, 2009 | Kohler 12 kW Emergency Power System -...
Overcrank error message
The 'overcrank' error simply means it tried to start but never actually started. It cranked for an extended period. Check the fuel and starting issues you would normally check to start the engine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Mar 31, 2009 | Kohler 12 kW Emergency Power System -...
Kohler 14resa 14kw Home Emergency Backup Generator Logo
Top Kohler Electrical Supplies Experts
Sheldon Dedek
rjivaro
J. Bradshaw
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
