Whirlpool 24" Double Electric Built-In Wall Oven Logo
Anonymous Posted on Jan 24, 2013
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
Model #RBD305PDB12 BOTTOM ELEMENT DOES NOT HEAT UP WHILE IN BAKE MODE
Steve Burt
Level 2:
Sergeant:
Champion:
  • Expert 245 Answers
  • Posted on Jan 25, 2013
Steve Burt
Expert
Level 2:
Sergeant:
Champion:
Answers
245
Questions
0
Helped
50094
Points
669
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
  • Anonymous Jan 27, 2013
    YES IT DID I ORDER A NEW ELEMENT YES YOU WERE VERY HELPFUL THANKS
4 Related Answers
Anonymous
  • 878 Answers
  • Posted on Jul 13, 2007
SOURCE: Electric Oven Won't Heat
Rob, sounds like it was just installed. You need 240V on this unit. On the terminal block in back where the power hooks up, it should read 240V across the two outer terminals and 120V from each end to center terminal. Im ruling out the thermal cut out because you never used it. I would start with the power source first. The display sounds like it's getting the 120V it needs to funtion, but I don't think your making the loop for the 240V needed for the bake and broil. Catriver.
Ken Bledsoe
  • 306 Answers
  • Posted on Dec 02, 2008
SOURCE: Bake will not heat up to where it should
If the oven is getting warm but not as hot as it should your thermostat is bad. They are a small pain to replace but can be done if you don't mind removing the front panel and removing 2 small screws. It would be best to get your model number and remove the thermostat to get exactly the same one. Let me know how it turns out. Ken
Anonymous
  • 226 Answers
  • Posted on Oct 17, 2010
SOURCE: Whirlpool oven RBS245prs....did a self
try unpulg it
Anonymous
  • 244 Answers
  • Posted on Nov 04, 2010
SOURCE: Whirlpool Self Cleaning Oven - Model
Your lower element may be burned out. Generally you can firmly grasp and pull it out. Take it to a repair shop and get a replacement unit. Then simply snap it back into the same outlet where you remove the first one. It sound as if you've tried everything else so it must be the unit that is bad.
1helpful
Built-in electric oven jtp15w2ww gets to temperature then quits. No error codes.
If your built-in electric oven is getting to temperature and then quitting during a bake cycle, and the upper heating element is not working during the bake cycle but works on the broil setting, it is possible that the problem is with the bake element. Here are some troubleshooting steps you can take:
  1. Check the bake element: The bake element is the heating element located at the bottom of the oven. To check if the bake element is working properly, turn on the oven and set it to bake mode. Open the oven door and look at the bake element. It should be glowing red. If it is not, then the bake element is likely faulty and needs to be replaced.
  2. Check the oven temperature sensor: The oven temperature sensor is a small probe that is located inside the oven. Its job is to monitor the temperature inside the oven and communicate that information to the oven's control board. If the sensor is faulty, it may cause the oven to shut off prematurely. You can test the sensor with a multimeter to see if it is working properly. If it is not, then it needs to be replaced.
  3. Check the oven control board: If both the bake element and the oven temperature sensor are working properly, then the problem may be with the oven's control board. The control board is responsible for controlling the oven's heating elements and other functions. If it is faulty, it may be shutting off the oven prematurely. In this case, the control board will need to be replaced.
It is recommended to hire a qualified technician to perform these tests and replace any faulty parts to avoid any risks of electrical shock or damage to the oven.
Nov 23, 2022 • Ovens
Does top burner in oven heat while baking
The top element may be burned out. That is the most common cause.
Larger heating element not working on outer
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Kenmore electric oven will not bake
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
1helpful
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
2helpful
Built in oven won't get hot
hello there
Usually, when an oven won't heat up or bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. Now if the oven It bakes poorly Here are two instances of when food "bakes poorly:" When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem
Hope thisis very helpful for you
Best regards Michael .
Mar 08, 2010 • Ovens
2helpful
Wont heat past 200 degres
May 27, 2009 • Ovens
1helpful
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
