Either the pc does nothing when I boot, only an orange light blinking on facade, either it starts for a while until the Windows logo shows and then it freezes definitly. HDD is ok, I could test it on another computer. I tested with another video card but no chance. Also tested to remove the first 2Go RAM and then the second but it gives the same result. Fujitsu Amilo pi 3630 with Windows 7 Intel core 2 Quad Q8200 2x2Go RAM DDR2 2 HDD SATA nVidia GeForce 9600 GT (512Mb)
SOURCE: acer aspire 5520
necesito la tarjeta de video para mi portatil ECER por favor ke alquien me ayude :(
SOURCE: No signal on monitor when card is seated
the problem occured probably because of a power shortage of motherboard battery malfunction, if your motherboard has an integrated graphics card you then need to enter setup and disable it or choose which graphis card your pc has to use but you have to do this while connected to the on-board vga slot as the other one won't be working, you will problably find the choice under the
'integrated periferals" menu in the setup menu, and to access it you have to press the "DEL" button when your pc starts-F10 in some devices-
SOURCE: Intel Core 2 Quad Q9550 2.83ghz displaying as Pentium III Xeon
This could simply be an issue with you bios. Flash to the latest bios version.
From the site it looks like the Mars has had some bios issues in the past.
Nice setup btw
SOURCE: new acer 1641 freezes up after inserting wireless card
HI,
SOME PLUG AND PLAY DEVICES ARE NOT COMPATIBLE WITH VISTA EVEN SOMETIMES IT SAY'S THEY ARE CONTACT THE MANUFACTURER FOR AND POSSIBLE DRIVERS THAT WILL WORK WITH VISTA.
SOURCE: graphics card failure
the error: (Under this test, results show Error code 5300: 0119, which different comments for different parameters) Msg: Detected a failure while writing and reading video memory. (e.g.) Video mode: Dh (320 x 200 16) Address A002Ch, expected to read Oh, but read 1Dh instead *
indicates the video card has failed and need to be replaced.
