SOURCE: Patton space Heater Model # prh-5
check that the rocker switch inside isn't stuck, when the rocker swings it shuts the unit off. if it is full of dust it may be stuck. may just be bad.
SOURCE: space heater will power up, but not start,
These fans have a safey feature (sensor) that shuts the heater off if it is tipped over. It sounds like this component is not functioning correctly - may be set wrong and will not allow the heater to turn on unless you shake it to reset the sensor. If it is still under warranty return heater, if not call Patton and ask for help.
SOURCE: looking for a phone number to contact PATTON SPACE
Patton at l-800-528-6600 ext. 1722 (Arizona: l-800-352-0458 ext. 1722; Alaska l-800-528-0470 ext. 1722)
SOURCE: I purchased the Patton PUH9000 heater last year. I
These have poor quality safety parts that fail in about 1 season or less, the failure rate for these little cheaper units is high, go Honeywell next time!
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
