SanDisk Sansa e250 MP3 Player Logo
Anonymous Posted on Jan 28, 2009
How do you put videos on your sansa fuze mp3 player with 4gb
I went on itunes and i downloaded it put it on my tv show saturday night live the best of chis flany but i tryied but it did not work i can only put it on disks
Jean Sintulaire
Level 3:
  • Master 759 Answers
  • Posted on Jan 29, 2009
Jean  Sintulaire
Master
Level 3:
Answers
759
Questions
Helped
185041
Points
1418
You will need to get the sansa media converter ...once you have it on your computer you can convert the videos into the player format..once you do so you should be able to transfer them..
I hope that helps..
Thank you
Computerrep
Why wont this sync with my itunes library?
Hi, Is the SanDisk Sansa Fuze compatible with iTunes? In some ways, it is. Unfortunately, the Sansa Fuze and iTunes don't always play nice together. You'll have to get a few workarounds to make these two sync together.
The SanDisk Sansa Fuze and iTunes
The SanDisk Sansa Fuze is natively a Windows product. You should be able to sync it with Windows Media Player automatically. However, not everyone owns a Windows PC and even if they do, they might store more music in their iTunes library.
If this is the case for you, you might find it helpful to be able to sync your Sansa Fuze with your iTunes music library. Bear in mind that you won't be able to sync apps, games or any other iTunes products that are not formatted for use on a Sansa Fuze.
Using iTunes with the Sansa Fuze
So, is the SanDisk Sansa Fuze compatible with iTunes? If you download the right software, it is. Apple offers a free download that works with many other non-iPod MP3 players, Sansa Fuze included.
Unfortunately, this product only runs on a Mac operating system. However, if you own a Mac, this is great news because it means you can still use your Fuze without buying a Windows PC.
If you use a Windows PC and want to transfer your iTunes music to the Fuze, don't lose hope - there's a way to do that, too.
Syncing the Sansa Fuze with iTunes
If you're using a Mac, visit this link for Apple's free software download. It comes directly from Apple, so you can be assured that it's spyware-free.
Install the software on your Mac. You need Mac OS X 10.4 or higher as well as iTunes version 8 or higher.
Plug your Sansa Fuze into the Mac and wait for the software to open. You should see a listing of your iTunes music library pop open in a window. You're then given the option to sync as many songs as possible onto your Fuze.
The syncing process is similar to syncing an iPod. Don't unplug the device until it's finished.
Syncing the iTunes Library in Windows
You can sync your Sansa Fuze with iTunes using a script called the Automator, found here. Once downloaded, open the script under your "Downloads" folder on your "C:" drive and find a string of characters that looks like this: "/Users/richard/Music/*.mp3".
Replace the name "Richard" with your own username. Don't change anything else. Select "File," "Save" from the menu.
Select the Automator icon with the right click button on your mouse and choose "Open with," "Automator Runner." If working properly, this should automatically sync the music from iTunes with your Sansa Fuze.
If that doesn't work, go into your iTunes library and highlight any DRM-protected tracks that you purchased from iTunes. Right-click and select "Make MP3 Version." These should now be compatible with the Automator.
This sounds like more or less of a "hack" than a solution, but this might be the only way to sync music from iTunes to your Fuze using Windows. If all else fails, make MP3 versions of the songs as shown above, then navigate to your iTunes folder where those files are stored. Then drag and drop these into Windows Media Player, where they should sync right onto your Fuze.
Hope that helps..
Have sansa fuze 4GB, downloaded aac audio files from itunes, copy and paste to my fuze memory, but can't access when i turn the player on- think i need to convert to mp3 format but don''t know how
http://download.cnet.com/Koyote-Free-Mp3-Wma-Converter/3000-2140_4-10442362.html?&cdlPid=10902033&tag=rtcol
This is a program that will convert them over to mp3 for your Fuze.
My Sansa Media Converter won`t download videos or photos into my Sansa Fuze 4GB.First when I installed the Sansa Media Converter it wouldn`t recognize my Sansa Fuze.After a lot of research on the Internet...
Google a program called
Video Download Studio
then you can use it FREE download video or audio form YouTube, google, metacafe, redtube, dailymotion etc. attention: download function is no need to register
you can also use it to convert video to audio, video to video, audio to audio.
use it convert video to mp3 mp4 for your iPod
tutorial;
http://www.downloadvideos-convert.com/how-to-use
1helpful
Video fomat
The Sansa Media Converter will handle just about anything you have on your computer. It should have come with the Fuze, but you can download the Windows version from http://www.megaupload.com/?d=3IPZO6Q0
1helpful
2answers
I don't know how to download music on my sansa fuze (4GB)
On your Sansa Fuze, go to the "Settings" menu, then go to "System Settings", then go to "USB Mode", then select "MSC".
Now, connect it to your computer, then double-click "My Computer" on your computer's desktop to run Windows Explorer. You should see your Sansa Fuze show up as "SANSA FUZE". Double click on "SANSA FUZE", and you should see a folder called "MUSIC". Copy your music into that folder. When done, unplug your Fuze and your music will be on it.
2answers
Please help.How do I put videos into my Sansa
ok try to use itunes software or windows media player software.
this may be user friendly for you.
Use itunes it is best
just add everything in the library then select synchronise to your mp3 player.
be sure to connect and your computer detect the mp3 player.
ok
cheers
uttam
I have a sansa fuze mp3 player and no user instructions
the menu has these function but you can download most of them from they site
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
2helpful
2answers
My sansa fuza 4gb shut off and it wont chare or come back on
Hi!
I had the same problem w/ my 4 GB Sansa Fuze after 3 wks. When I took it back to Future Shop I discovered a commis who showed me the secret way to debug it . You have to push & hold down the "Home" & the "Down/Submenu/Options" buttons simultanuously to reset it. It worked for me.
Which format or what kind of videos should i download in order for them to be compatible with my player
use the sansa media converter on this website to convert you videos to the right format and if i remember right it is mpeg something im not sure
Videos wont show
Sansa Media Converter must be used to put any video on the Sansa Fuze. Its freeware so just type in http://mp3support.sandisk.com/sansa/SMC for the free download.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
