The ipod volume on my Clarion NX602 is really loud at the lowest volume setting. The volume is fine in all other modes. I have tried adjusting the volume on the ipod itself, but it doesn't change anything. How do I get my volume back to manageable levels. This happened right after i updated the software to the latest version. I followed the update instructions to the letter.
I have the same issue. Started a few weeks ago by locking up the unit while using the nav. Then the nav app will not load at all. Any luck on getting a resolution?
Setting the Clock :$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile again. pressing the Function button 1 a to enter 2) Use the Up and Down buttons to adjust the clock display mode. the volume. 2) Press and hold the BAND button m, while A : Increases the volume. pressing the Function button 1 for 2 sec- V: Decreases the volume. onds or more. This enables clock editing. ,#A Ci'4UTlOM Audio Mode Adjustments Press and hold the BAND button m, while 1) Press the AUDIOMODE button to select the adjustment mode. The mode switches as follows each time the AUDIO MODE button is When this unit is turned on, starting and stop- pressinq the Function button 1 at the same pressed: BASSrrREB + BAUFAD -B Previous mode 2) Use the Left and Right and the Up and Down buttons a, to adjust the bass and treble. -=Adjusting the bass> bb : Bass gets stronger. 4: Bass gets weaker. -=Adjusting the treble:, A: Treble gets stronger. V : Treble gets weaker. 3) Use the Left and Right and the Up and Down buttons a, to adjust the balance and fader. <Adjusting the balance> W: Sound from right speakers gets stronger. 44: Sound from left speakers gets stronger. <Adjusting the fader> A: Sound from front speakers gets stronger. 8 : Sound from rear speakers gets stronger. *The editable fields will be indicated by flash. 3) To move between the hour and minute fields, use the Left (hour) and Right (minute) buttons a. 4) To.store the clock setting, press the BAND button a.
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume • With the handset or base in idle (off) mode, press MENU then press ▲ or ▼ until RINGER VOLUME is shown • Press SEL. You will hear a sample of the ringer • Press ▲,▼ or a digit (0 through 6) You will hear a sample of the new ringer volume and the volume bar will be increased or decreased each time the setting is adjusted At the lowest setting the ringer will be turned off and the display will show: - OR - • With the handset or base in idle (off) mode, press or of the volume control will directly go to ringer volume menu • Press ▲ or ▼ to adjust the ringer volume
try the volume setting on your ipod. it may have to be adjusted. go to settings, volume and see where you are on the slider and adjust to the volume you want. ipods come factory set at a predetermined volume level.
Maybe the owners manual would help. It says you can adjust the sensitivity of the AUX input through a menu. It sounds like the AUX sensitivity is just set to max. Look for the 'to change other settings' chapter, instructions are in there. If you don't have the manual, find it on the official website. http://www.clarion.com/us/en/products/2005/audio/source_units/cd/DXZ555MP/us-en-product-pf_1133851137392.html The link to download it is on the upper right.
Sorry I don't have a solution. We have this model and ours is loud also, at the very lowest setting. I disconnected some of the speakers, and sometimes have to put the working speakers into a drawer to lower the sound.
