Apple iPhone Smartphone Logo
Lynn Lozon Posted on Jul 24, 2007
Calender The times in my calender are off anywhere from 2-4 hours, I have checked that it is set for EST, etc. It is correct in my Microsoft outlook but comes over to iphone incorrectly? Help?
Donal Botkin
Level 1:
  • Contributor 33 Answers
  • Posted on Jul 27, 2007
Donal Botkin
Contributor
Level 1:
Answers
33
Questions
Helped
32925
Points
42
Try switching to 24-hour time on both PC and iPhone and set both to sync with "atomic clock" time (time.apple.com Win has one too) Are the minutes right? If not, the "daylight-savings" solution is incorrect.
A
Anonymous
I think it has to do the daylight savings time. Try turning off he auto correct on the iphone under settings
1helpful
I have set my timer for every 2 days at 0500.. i set it this evening the 17th, will it start on the 18th at 0500 or on the 19th at o500 and then on the 21st etc ???
if you have the clock and calender set correctly , then setting a 2 day setting will start from midnight of the next day
so if you have it set correctly then the program will click in from midnight tonight and move forward 2 days or 48 hours.
so switch it on today at midday ( example 17th ) it activates when it passes midnight in 48 hours time to switch on at midday on the 19th
1helpful
I understand i can set my calender on my laptop to remind me of appointments how do i do that
Hi steven1960,
If the Microsoft Outlook Application is installed in the Computer, you can set reminders using that. If not, you may use another applications like Google Calendar or creating the .bat files. To create a reminder for an Appointment using Microsoft Outlook, please open the Outlook Application and press the Ctrl + Shift + A Keys. This will open an new appointment window. You can set the reminders there.
Hope this helps.
Good Luck!
Please post back if you require further assistance.
Thanks for using FixYa.
How do i change my ringtone on my Palm Treo Pro Smartphone? I cant seem to change my ringtone at all!
I have synced Gooldle calender withoutlink calender and then ActivSync 'ed to my Palm Pro, the phone calender does transfer the meetings, but all the metings are 1 hr delayed. For instance, a meeting in google / outlook calender at 9am transfers to 10am on Palm - any advise?
MS Outlook bootup- don't want inbox to show
inbox is must in any outlook profile, but you can setup calender for example to be default at MS outlook startup. go to
tools-->options-->other-->advanced options-->
look for start up in this folder field-->Browse
then choose your folder(calender or contacts) .
all the best
Outlook 2003
Is there not an Accept button available in the email received? Are the senders using MS Outlook as well?
Treo 650 calendar not syncing back to Exchange
I am experiencing the exact same issue. Are you saying that this only occurs with one of your 650s? If so then maybe it is a hardware issue.
How to change the default handler from Outlook to Palm desktop?
Change sync methods from outlook to palm desktop !!!!! Hi, There are two ways to change the sync methods : 1. Insert the installiation disc into the cd rom device , u will get a window called dicover ur handheld , there please check for change ur sync methods , and u will get another window sayin ur currently using microsoft outlook to sync , would u like to change to palm desktop , say yes and then u will get congrats , click on finish . To make sure it is changed from outlook to palm desktop , right click on hotsync manager at the bottom right corner of the pc , make sure only local usb has a check mark and then left click on custom , in custom check and see if u see calender [outlook] or just calender , if u just see calender , then presuming all the data is in handheld , highlight calender click on change and change the action to handheld overwrites desktop then click on ok , do the same for contact , tasks and memo then click on done and perform a hotsync. 2. Insert the disc , open up my computer , then u will see ur cd rom drive , right click on it and left click on explore , u will find yellow folders , please check for a yellow folder called post install , open that up and inside that u will find outlook switcher , left double click on it and follow the same procedure as told in the first step . Regards
Hotsync with an additional calender in MSOutllok
Chapura PocketMirror Pro has a multiple Calendar feature that might help you.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
