Question about Olympus VN-2100PC Digital Voice Recorder
Hardware is not recognised - Olympus VN-2100PC Digital Voice Recorder
Where can I download the free driver for my 1997 creative sb0200 5.1 sound card.
When you can't get them from creative it is a challenge.
You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems.
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems. So to make sure your hardware is compatible with the OS. Check the manual and find out, what you have to do so it will work on your computer.
Mar 22, 2015 | HP Creative Sound Blaster Audigy 5.1
Usb 3.0 driver
When you connect something to an USB port for the first time, don't hope to much. You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for most hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible with the new operating systems.
So to make sure your hardware is compatible, check the manual and find out, what you have to do so it will work on your computer.
If your device was working on a USB2 port, it also should work on an USB3 port, on the same computer. But don't expect another speed, because the slowest part decides the speed.
Jun 24, 2014 | DekCell EasyCap USB 20 Video Capture...
How to dekcell easycap for win 7 64bit
You have to be sure the computer has the correct software to recognise the hardware connected to an USB slot and can work with it. From Windows 7 and up, for most hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible with the new operating systems.
So to make sure your hardware is compatible, check the manual (or box where the hardware came in) and find out, what you have to do so it will work on your computer.
For older equipment you can't find drivers, because most producers of hardware, don't work on certification of old hardware. They only develop and work for certification with Microsoft for the parts they want to sell now.
What can be done to solve the usb port problem with my hp630 core i3 windows 7. It only flashes light but does not display or work.
When you connect something to an USB port for the first, don't hope to much. You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for most hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible with the new operating systems.
Jun 22, 2014 | HP Smart Buy 630 Intel Core i3-370M...
Computor wont recognize dvd player
You might need to have a computer administrator account to perform some tasks.
Most new devices your computer will recognise automatically. When your comp is running, plug in your new dvd player. Does it beep and say 'New Hardware added? If not then use
The Add Hardware Wizard which enables you to add new hardware or troubleshoot any hardware-related problems.
Open the Add Hardware Wizard
  • To open the Add Hardware Wizard, click Start, click Control Panel, and then click Printers and Other Hardware. Under See Also, click Add Hardware.
  • If it can't recognise the player, it gives you the option to select the correct make and model. Is yours on the list? If not, you may need to go to the Microsoft site and update the list of players.
  • Do come back here if you need further help.
Dec 28, 2013 | Televison & Video
It turns on but freezes at the please wait and then later shuts off. I plug it to computer and it does the same. I tried looking for my producr on cobyusa.com but its not there. What can I do?
The computer can't find a driver for the router.If you have a disc that came with the router reinstall it,and follow the instructions on the screen.Also try unplugging the router and plugging it back in again.Your computer has to recognise the router hardware.Go to control panel and hardware and install device.It may recognise the hardware but not have a driver to make it work.
Aug 07, 2010 | Computers & Internet
My nokia 5310 Xpressmusic is no longer recognised by my computer
Uninstall all of the Nokia-related software on the affected computer, reinstall it, and THEN plug it back into your computer.
Jan 12, 2009 | Philips GoGear SA3125/37 MP3 Player
Ipod 30GB
Unplug your ipod anyway & hope you don't lose data.
For it to recongnize, maybe try:
1: go to control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your ipod is now recognised by the computer
---John
Give credit to Randomassist
Jul 31, 2008 | Apple iPod MA446LL/A MP3 Player
PC not recognising hardware
Sansas only work on WinXP or later. Win 2000, ME, 98 and 95 are not supported.
Jan 03, 2008 | SanDisk Sansa m240 MP3 Player
Olympus VN-2100PC Digital Voice Recorder Logo
24 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
