Question about Lexar Computers & Internet
Lexar 32GB USB Flash Drive. Not recognized, or recognized for a short time then disappears from drive selections.
At one time, CPU would recognize the drive and indicate it had a bad file and ask to correct it, which I approved. Now when I insert it, it is identified by the USB interface as having a malfunction. Has less of a problem being reliably recognized on another system, but, exhibits similar issues there also.
    Sergeant:
  • 305 Answers
Flash drives give notices like that when the files or system on them is corrupted. Put it in again, and select "fix problem" if that option shows up. If not, go to file explorer, find it and right click on it and click "format". (you will lose any files on it, but by this time probably anything on it will be useless anyhow.) If none of these work, you may need to buy a new one.
Posted on Jan 03, 2018
SOURCE:
icansurf
  • 72 Answers
SOURCE: lexar jump drive
Take it to a Wal*Mart for an exchange
Posted on Dec 04, 2007
suisboy
  • 175 Answers
SOURCE: Lexar 4 GB Jump Drive
check for the USB drivers Of the Laptop.
Could be problem with the Laptop USB Controller Driver.
Posted on Jan 08, 2008
  • 86 Answers
SOURCE: lexar flash drive
First, download and try to extract all the files from your drive with this tool:
http://www.lexar.com/drivers/files/ImageRescue_2.0-u(b16).zip
Second, at the moment that you are sure that you have all your files backed up, if windows recognizes the drive, try to right click on it and format
Posted on May 06, 2008
mastersaintx
  • 928 Answers
SOURCE: My computer is not recognizing
Have you already formatted the memory card? you may do this via the console of your camera. Sometimes you have to format it first before taking pictures as the computer will not recognize it. Please try a USB flash reader as well. by the way another symptom is that your Memcard is configured for 2.0 if your port on your computer is for 1.0 it might not be backward compatible. This happened to me on a Canon but it might be the case with yours as well. Please try to see if it will be read on another computer.
If you need further assistance please do message me.
Posted on Sep 07, 2008
Hello Kitty 8Gb flash drive isn't recognized on PC
physical damage is the most common reason a flash drive isn\'t detected. The connection between the USB connector and the circuit board can become disconnected after even normal use. A telltale sign is a loose or bent connector, but sometimes the damage is undetectable with the naked eye. if you want to do this your self..If you accept the risk and choose to repair your flash drive yourself, the first step is to apply light pressure to either side of the flash drive while it is inserted. Make sure the sound on your computer is on so you will hear the "ding" if the connection is momentarily reestablished. If you do get an indication, you can try to hold your flash drive in the position that causes it to show up. While you hold it in place, ask someone to access the drive and save your files to your computer. This requires a steady hand and if you have a lot of data on your flash drive, you might have to hold it in the same position for a long time.
Aug 09, 2014 | Hello Kitty 8GB USB Flash Drive
I need the driver for a ST9250320AS disk, ive been searching for days.... for some reason... i can't run a driver scanner. when i try to install windows 7 on my laptop, it display an error asking...
how old is your computer
if your computer is asking for a driver when you insert the windows 7 disc your motherboard might not support windows 7 if its older than 5-6 yrs also you need a minimum of 2 GB of ram to support windows 7
hope this helps you
Sep 01, 2011 | Seagate ST9250320AS 250 GB SATA II Hard...
After inserting the correct cd , computer is asking for the cd crom ??
This is happening when it needs the crack to be inserted ..somehow it does not recognize the disk ..In original these games were made to be played directly from the disk ..Inserting the disk will not fix it cause the files it is looking for aren't there.What you need is the crack for the game ..it is just an executable file ..that need to be copied in the director of the game ..and will replace the original start file ..
if you find it ..download and copy to C drive /program files..in the folder of the game ..it will ask if you want to replace the file..and you have to confirm the action .
Jul 05, 2011 | Sega The Incredible Hulk: Ultimate...
Having transcend 4 GB pend drive but when i insert into my laptop the drive did not open
When a pen drive isn't recognized it is either the pen drive or the usb port. First thing is to try it in the other ports. You can try rebooting the computer with the drive not connected and see if it finds it. Next try it on a different computer. If it finds it then the problem is on the usb port on the first computer.
If it is not recognized on any computer then the pen drive has failed and it is unlikly that you can do anything but replace it with a new one. If it is recognized but not being read on any computer you may be able to use the systems error checking tools to correct the problem and use the drive again. You can also format it and get it working but you loose your stored information.
To use error checking:
Detecting and repairing disk errors
  1. Open shortcutcold.gifMy Computer, and then select the local disk you want to check.
  2. On the File menu, click Properties.
  3. On the Tools tab, under Error-checking, click Check Now.
  4. Under Check disk options, select the Scan for and attempt recovery of bad sectors check box.
note.gif Notes
  • To open My Computer, click Start, and then click My Computer.
  • All files must be closed for this process to run. If the volume is currently in use, a message box will appear prompting you to indicate whether or not you want to reschedule the disk checking for the next time you restart your system. Then, the next time you restart your system, disk checking will run. Your volume will not be available to perform other tasks while this process is running.
To format it: use the same instructions and instead choose the format option.
If none of that makes it behave all you can do is replace it.
Aug 10, 2010 | Computers & Internet
I have a Dell. My Roxio prog doesn't recognize a discs
That means there is something wrong with your driver. If it cannot read any disc you inserted then the problem exist in your drive. You don't need to reinstall any driver as long as you can see your drive being recognized by your computer and you can see your drive in the My Computer with a letter indicated on it. Your drive is in need for a replacement. This problem indicates a hardware failure specifically the lens of the device.
Hope this helps..
Mar 29, 2010 | Acer (4432A-002) CD-RW Burner
DS won't recognize inserted card.
Try a nintendo approved DS Card in the system, if you can't get that to take then you know the slot in the DS is bad and the DS needs to be replaced.
If you can get a nintendo approved DS card to work then you know that you need to stay away from the 3rd party cards.
Aug 27, 2009 | Nintendo Video Game Consoles & Games
When I connect my WD to the CPU the light comes
Make sure you have the power plugged in plus the flat cable. Unplug the drive and start your computer. Power computer off and try hooking it up again. Windows should find it. If it doesn't, do you have the CD that came with it? If you do, go to control Panel, add hardware, and when it prompts you, insert CD. It should find it. If it doesn't find it the first time, I have had success on the second or third try, so don't give up. Hope this helps.
Jul 03, 2009 | Western Digital WD Passport 250GB Portable...
Memorex external usb floppy disk-drive does not appear or functio
As I understand it the computer recognizes the floppy drive.
Can you read other discs, write to them etc? If not drive is bad
If you can read other discs then your floppy disk is bad
Jan 23, 2009 | Memorex Computers & Internet
Mother board or CpU Doesnt work. technician said I have a ghost inside my CPU!
verify your bios settings with regards to what the pc is expecting in way of hard drive.
Do you have the luxury of another hard drive that you can try on this pc ? - this will 'suggest' where the problem rests.
Make sure the lead is fully located on the back of hard drive.
If possible - change the lead for a 'known working' lead (Maybe from the computer that your hard drive was recognized in)
Aug 15, 2008 | Seagate (ST307504FPA1E3-RK) Motherboard
REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
May 19, 2008 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
Computers & Internet Logo
165 people viewed this question
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
gggg
Dayton Computer
Dayton Computer
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
