Delta Luv Delta - Baby Products 5-in-1 Crib Logo
A
Anonymous Posted on Jan 24, 2013
Need manual for a delta delta seville crib model #4624-1
2 Related Answers
Anonymous
  • 74 Answers
  • Posted on Sep 13, 2009
SOURCE: Need a copy of the assemble instruction for a
if you go on the website you can read or download the instruction manual
Anonymous
  • 502 Answers
  • Posted on May 11, 2011
SOURCE: i have a delta luv crib that i need parts for
Ask the crib manual search engine, they will get it within hours.
1helpful
I would like to know if this crib model has a recall " model # 4624-1" date of Man. 03/24/06 Thank You
Here is a link to check using the date of manufacture and model and style.
They used a finger pull style and a shin push. Just follow the directions
and they will send you a free kit. It does appear there is a recall for it.
http://www.cribrecallcenter.com/recall.asp?pa=1
13helpful
2answers
I have a Delta Luv Crib Model 4885, Order No. W24255 Date Nov. 2004. Is there a recall on this crib?
Luckily I didn't see your model listed in Delta's Crib Recall. Below is link to Delta's website and a list of all Delta cribs recalled.
http://www.deltacribrecall.com/
If this information is helpful, I would really appreciate a "thumbs up" rating!!
Delta cribs manufactured in Taiwan or Indonesia, with the “Crib Trigger Lock with Safety Peg” drop side hardware design, numbers:
4320, 4340, 4500, 4520, 4530, 4532, 4540, 4542, 4550, 4551, 4580, 4600, 4620, 4624 (production dates 01/06 thru 11/07), 4640, 4660, 4720, 4735, 4742, 4750 (production dates 01/95 thru 12/00), 4760 4770, 4780, 4790, 4820, 4840, 4850, 4860, 4880, 4890, 4892, 4900, 4910, 4920, 4925-2, 4925-6, 4930, 4940, 4943, 4944, 4947, 4948, 4949, 4950, 4958, 4963, 4968, 4969, 4980.
Delta drop side cribs manufactured in China through 2005, with the “Crib Trigger Lock with Spring Peg” drop side hardware design, numbers:
4340, 4343, 4520, 4600, 4620, 4624, 4625, 4629, 4660, 4665, 4720, 4750, 4751, 4850, 4855, 4857, 4880, 4920, 4925-2, 4925-2B, 4925-6, 4980, and 8605.
The drop rail on my Seville crib, model #4624-1 keeps coming off the track and I see it being potentially dangerous as the baby gets bigger/stronger. Is there a kit to fix this?
i tried researching and found some complaints on it but no recall...i would look at your owners manual for an address or phone number and contact the company... i also read that the paint comes off easily? if you just recently bought it i would return it to the store and get it from another manufacturer...better to be safe than sorry.
2helpful
Is Delta Luv Crib 4980 built 12/3/03 on recall list
Hello Shohola107,
I found this recall list. I did see your model listed. Here is the list.
You can also check out this website. http://www.deltacribrecall.com/recalled_products.asp
Thank you
5helpful
Has Delta Luv crib model 4624-1 been recalled
Yes, please follow the link below for the replacement part order form.
http://www.cribrecallcenter.com/cinfo.asp?recall=2&co=1&m=4624-1&p=90002
If this information was helpful, please take a moment to provide a "thumbs up" rating. Thank you!
2answers
6helpful
3answers
I have a delta luv crib that i need parts for
Try Products America. You can see their avaiable hardware online at www.productsamerica.com or www.productsamerica.net, but to order you have to call and talk with one of their trained CSR's at 800-205-9642 or 800-772-1041.
Looking for metal pins, safety pegs, and metal screws for delta luv crib model #4624-1
You can contact Delt Luv at 800-377-3777. Hopefully they can help with your parts. If not, you can call Products America, they may not be able to help you with the hardware but would not know for sure until you have spoken with them and given some general information about the crib. Their numbers are 800-205-9642 or 800-772-1041. You can also check their websites for the parts you are missing to see if they have them. The website are www.productsamerica.com or www.productsamerica.net.
Model 4624-1 Delta Luv Crib
If its like mine, you just remove the front panel that went up and down. Then lower the wood mattress support to the lowest level. You are now ready for the toddler bed. Once you want to convert to a double bed frame. You have to purchase a metal frame that holds the bed. Then attach the back and the front to the metal frame. This should like a sleigh bed. Good Luck, Nicol
2answers
Need Replacement Parts
called 800-377-3777 and promptly spoke with a customer service representative who courtesly told me the necessary information required from the crib mattress base in order to purchase replacement parts. There was no hassle. FYI in order to get replacement pts,, you need crib model, order date, where manufactured, part numbers (all on the base of crib). Thank you so much for your assistance.
Top Delta Luv Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Delta Luv Baby Gear Expert? Answer questions, earn points and help others
