MSI N1996 motherboard installation CD
A lot of people were looking for N1996 board drivers, thinking that N1996 is the model number for their MSI products, such as MSI motherboards, optical drives, VGA cards and etc.
Well, that is not the model number because it is not possible that alot of products sharing the same model number, right?
Then some one on forums mistakenly saying that N1996 is MSI FCC
identifier printed on all MSI boards/optical drives/VGA cards, which is
NOT TRUE as well. To know what N1996 means to your MSI products, see
below for the proof:
According to MSI official website,
A C-Tick mark (see above) may also appear on our MSI products that are
required to comply with Australian electromagnetic compatibility
requirements and radio-communications standards.
It signifies that the product may be legally sold in Australia. Now it
requires EMC compliance must be marked with the C-tick logo and ACA
supplier code number. The ACA supplier code is N1996.
The supplier is responsible for holding a Compliance Folder that
contains compliant test reports and a Declaration of Conformity.
This is more about ACA supplier code. According to ACMA
(Australian Communications and Media Authority), Supplier Code Number
means the number issued to a person by ACA or ACMA upon application for
registration to use the compliance marks (A-Tick or C-Tick).
So now you know what N1996 means for MSI products. To find the
MSI drivers, you need to find out the correct MSI model numbers, for
example here are few of the correct MSI model numbers/codes, hope you
can see the pattern here:
Try looking for it on manufacturers website
Hello the drivers can be downloaded here:
http://www.msi.com/product/mb/K9N6SGM-V---K9N6PGM-FI---K9N6PGM-F.html#/?div=Driver&os=All
Please select your windows system.
Next click on the driver you need for download.
The file is compressed to the zip format, so you need to unzip the file before you install the driver.
I recommend to install the chipset driver first and reboot your machine.
There are many models of this mainboard, so the drivers can be different.
Try also to enter the bios, by pressing the del button when the machine boots up.
In the bios you can tell what MS XXXX number the mainboard has.
The MS XXXX number can be used here:
http://dk.msi.com/service/download/
In seach for the drivers, if i am incorrect.
Just enter the number in the seach field, and press go.
The mainboard number is sometimes placed on a sticker just below the power supply.
Try also google seach when you find the ms 4 digit number.
N1996 does not help in the seach field.
This type of mainboard has been used in the brand: HP, Hewlett packhard and some others.
So a seach on the manufactures site of the pc is also an option.Best of luck
SOURCE: Motherboard cd installer lost
If you install Windows XP.most probably you need not require the CD,,
SOURCE: i lost my motherboard driver's installation cd
Look up your mode of the pcchips website and download the driver:
Link:
http://www.pcchips.com.tw/PCCWebSite/Support/Category_Support.aspx?MenuID=3&LanID=2
msi
Motherboard
Hello your mainboard belongs to the HP/COMPAC site You can`t find the driver at MSI. You have to visit the HP site here: http://www8.hp.com/us/en/support-drivers... Enter the full HP number or computer model. Next select your windows system. And download the network driver. If in doubt click on: How do I find my product name / number? I think its this driver: http://h10025.www1.hp.com/ewfrf/wc/softw... Just click on this file for download: sp27426.exe Good luck and hope this helps you :-)
