Heating & Cooling Logo
Posted on Jan 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water level float switch error
Air conditioner screen switched off and showed -Water level float switch error. We reset the airconditioner and it is now running.
What does this fault mean, and where is the float switch on reverse cycle LG air conditioner
  • Anonymous Mar 25, 2014
    My central ac won't turn on after running, by playing with the float switch I get it to run
Anonymous
Level 2:
  • Expert 400 Answers
  • Posted on Mar 05, 2009
Anonymous
Expert
Level 2:
Answers
400
Questions
0
Helped
225250
Points
937
You do not mention the model, I presume that it is a cassette, in which case the float switch is located in the indoor unit. You have to remove the cover which is 4 screws. First make sure all power supply is turned off. Then remove the drain pan which surrounds the fan blade. You will see in one corner of the unit a slightly deeper part of the drainpan, this is the corner where both the condensate pump as well as float switch is located. Before you do any of this, give a serious blow into the drain pipe from outside and this may dislodge any sludge which may be causing the floatswitch to stick. You can also pull out a rubber plug which is under the pump on the drainpan.
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
tip
Error code CH-04
In LG multi split/cassette type units, error code ch-04 means Float switch Open circuit (High level water alarm). Dis assemble the indoor and clean drain pan.
on Jan 11, 2011 • Heating & Cooling
I have a Haier split airconditioner HSU-22HD03, it runs for 5 minutes and then switches off and the power and timer light start flashing.
It shows your indoor PCB faulty. (As you didn't mention any error code). Next time count the green light flashing and write.Thanks.
Red bucket full light stays on.
If the bucket is full then the pump should be running, if the pump is not running it is a faulty pump motor, a faulty control board, a faulty level switch for the pump motor or the water level alarm float switch.
2helpful
2answers
Water resevior is empty and light stays on?
If the high water level switch closes, the
compressor and condensor fan motors shut
off, and the water full indicator LED lights. The
water must be drained manually. Since you have dumped the water the high water level switch must be stuck in the off position. Page 42 of this manual shows the high and low water switch cover plate removed and the floats. Check the floats to see if something is making it stick or it has a hole in it. This manual is from WP but I imagine all of them type ACs come from the same source. PORTABLE AC SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2helpful
My Sunpentown WA-1210E airconditioner stopped working. It emitted several beeps and the power light is blinking continuously. When I unplug, wait a few minutes and replug in the unit, it shows the same...
Have you checked the water container in the unit? It has a float switch that when it is full it will not allow the unit to run so that it will avoid spilling water on to the floor. Hope this helps 2rns4u <*{{{>(
Air cond drain line
did you check that it is level
5helpful
Air conditioner has to be reset --E1
If your a/c unit is portable,and E1 code most always is "air filter cleaning time" or" water level to high ".
To reset air filter interval turn unit off at power switch then unplug.Hold power switch down while plugging in....unit will go through a short self check then beep.Release power button after beep.Unit should now be reset.
To reset water level....just drain some.....not all.
Most portables use water for increase cooling......so leave some in.
2answers
Mitisubishi Ducted Reverse Cycle AirConditioner
1.check blower fan motor.if blower fan motor donot work then compressure trip after 5 to 10 minitue.
2.make switch of airconditioner n reset again.
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
