I have a problem with th TK3202E when I fit a charged battery the radio thinks it has not charged I have checked the voltage on the battery and it is fine I see from the programming software that the low battery level can be changed using the single point reference level adjustment. How do you do this
First put the dead laptop battery in a zip lock.
Then put the zip into refrigeratory and keep it in freezer for 14 - 15 hours.
Afer waitinf for a long time, take the dead laptop battery out of refrigeratory .
Using clean and soft cloth to dry the battery and get the battery to room temperature (about 20° - 25°)
In the end fully charging and discharging the battery for 3 - 4 cycles.
Now you would see that your dead battery holding up charge for 1-2 hours.
See the detail video in metacafe.com
Steps to try: 1:adjust volume up 2:Check batteries are fully charged 3:adjust squelch level
If all fails, join yahoo group specific to Cobra HH38WX and they'll give you the lowdown on this unit and you can freeely dowload user manual as well as other great stuff.
If neither of them work, then that would suggest something common to both... the Charger? Are you sure it is OK? Is it making good connection, give them a clean/scrape. Otherwise it could be dicky batteries, they go faulty all the time & for no apparent good reason.
Check your battery contacts on/in the radio, battery and charger. Clean with a pencil eraser if needed. If your charger will accommodate the battery alone, try charging the battery outside the radio. Does the charger's light (if any) come on and stay on when the battery/radio is attached? If so, your charger is working properly. If the light (if any) on the charger is flashing you may have a shorted or bad battery. Check your user guide to the radio/charger for more information. Finally, periodically a battery has too low of an initial factory charger to start charging on the charge immediately. Try placing the battery on the charger for 3 complete charge cycles, and see if it will then charge. If the battery is new, you might want to contact the vendor for a replacement.
first of all check the volume control see if a wire broke off. but i suspect a cold solder joint on that volume control switch. if not check the board for a small crack.
Your power settings may be set up to inform you at 90% the battery is getting low.
Windows XP
Go to control panel, Performance and Maintaince(only in catigory view), Power Settings click Alarms tab and adjust the sliders to the desired.
Windows Vista
Go to control panel, click change battery settings, find the option selected click the link below it saying Change Plan Settings, click the link change advanced power settings, go to the battery section and adjust the low battery level and critical level.
Check the battery first..... alot of times a person will put a battery in a chager and let it sit. They will think the battery is fully charged but it may not be...
In those battery packs there are a bunch of smaller batteries all tied together. Alot of times these commercial raios will run off of around 7 volts ( check the battery). The battery will only charge up to 7 volts if all the cells inside the battery are good.
What I'm saying is for you to charge the battery up fully..... check the voltage listed on the battery then use a volt meter to check the voltage after the battery is fully charged.
When a battery has just finished being charged usually it will be overcharged.... a 7.5 volt battery will be up around 8.5 volts for example.
So check the battery right after its charged... expect it to be overcharged. If it seems OK, put it in the raio and key the radio for a bit to try and use up some battery power.... then check it again and see if it has dropped drastically.
Your problem has to do with power... the first link in the power chain is the battery... check that out... then go to where the battery makes contact with the radio and make sure thats good.... inside the radio there will be a fuse but if thats blown you will get nothing... then the power goes to the switch.
Battery... contacts...fuse... switch... that how the power initially gets into the radio.
Most of these problems are battery related so I would check that first. If the battery does not have enough power when you transmit with the radio the radio will shut down.... turn off. If its not getting enough current the voltage will drop and once it gets low the radio shuts off. Usually with commercial stuff you will hear a "beep" when this happens.
Your problem might be power related... theres alot you can check.
