I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
SOURCE: whirlpool Jacuzzi with 10 jets one stopped working.
either one of ur hoses has come off or is stopped up get to the sides and see if one has come off
