which password, power on password or o/s password? if its power on password you need to reset BIOS. by removing the coin cell battery on the motherboard together with a jumper just next to the coin cell. its called CMOS. Power on the computer and all the bios settings will be reset including the passsword. if its o/s passord that is created in the control panel you need to use a software called password xp.
The steps are: Step1:Download and install Windows Password Reset from http://www.windowspasswordreset.net Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB. Step3:Put in your newly created CD and remove your Windows Password . So easy,right?
Call Dell for this, I work for Dell Before and the supervisors or what they call the tools to reset BIOS passwordo n your system just call dell and give them your service tagg on the sticker on the bottom of your laptop .... Dell can create a bios password to crack the passord on you bios using your sevice tag
Du kan ha skrevet inn feil passord første gang du setter den i, så det er å huske feil passord hver gang.
Prøv å fjerne merket "lagre passord" og sjekke e-post, legge i riktig passord, og deretter merker du lagre passord og se om den gjør dette neste gang du sjekker.
Vanligvis feil passord ville forårsake problemet du har.
ENGLISH:
You may have typed the wrong password the first time you put it in, so it is remembering the wrong password each time.
Try unchecking "save password" and then check e-mail, put in the correct password and then check save password and see if it does this the next time you check.
Usually an incorrect password would cause the problem you are having.
