I've had this phone for a while now and it was working just fine until friday when the battery went down and i charged it.It never charged.The LED light on the phone goes from red to orange to green in a matter of minutes and when i switch it on the screen lights up with these numbers IPL 1.00 SPL 1.01. 1.109 GSM 0.3.28.60 CLEAN HIVE (1) N FORMAT HIVE(2) N Sometimes I press keys 1 and 2 to change the N to Y all to no avail. Could anyone please help me to determine the nature of the problem and any solutions? Thank you
I had the same problem . even in a charger the light will goes from red to green in a min
try a pretty thick USB cable. card reader cable that wont work any way.
i hope this will helped you out
Khanz
Cheers mate.how can i update my rom?
Dear, your phone is charging but you are stuck in bootloader mode, you have to update your rom
I now charge the phone all day all to no avail and the green light(idle mode)comes on however anytime i switch it on the screen fades before the 'Windows mobile'screen loads.
I have the same problem as billuxv's. I heard that the battery normally dies if you drain it all by using your phone and if the battery is completely dead you can not charge it afterwards. but if you charge it while your phone is on than the battery will keep on chraging the battery in normal way. I have used about 12 batteries(bought from ebay) and all of them died like that. this time I am not letting my phone to drain all the battery becuase i charge it again before it is drained. It is hard to keep the phone all the times charged but this way you may keep on using your phone.
