Question about Karbonn K9
Karbonn k9 charging problem
Charging jack ok but not show charging
    New Friend:
Karbonn k9 charging problem not save
Posted on Dec 23, 2016
3 Suggested Answers
SOURCE:
SOURCE: manual wap settings for karbonn K9
keypad not work
Posted on Nov 16, 2012
  • 4 Answers
SOURCE: internet setting for karbonn k9 my sim card is idea pls help setting
Make sure the Address is typed in correctly. Check for errors like "ww." ".coom"etc.
Learn more about 404 Errors:
http://en.wikipedia.org/wiki/HTTP_404
Posted on Oct 22, 2012
I have acer aspire 5334. AC adapter plugged in but won't charge. Lights not showing on laptop and battery icon not showing its plugged in. Adapter rectangle box led light is on!! Is it charger, battery or...
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place.
Dec 10, 2012 | Computers & Internet
Aspire 5935 G plugged in not charging 0% aviable
If you are sure the charger is OK, then the possible cause could be the battery or the power jack.Take the battery out, and plug in the charger, if your laptop works, then the power jack is OK, you need to replace the battery; If not, then it proves the power jack is broken, it need to be resoldered or placed. Or you could directly test your battery with a digital multimeter.
Mar 31, 2012 | Computers & Internet
Voltage from the Power jack is not powering up the computer or charging the batteries
Sadly FIXYA has no idea if or where you will find either of these requests . keep searching thru Google
Dec 23, 2017 | Gateway DA0MA2MB6D8 6000 and M360 Series...
My nokia n72 does not charge even the crarging jack is ok what is the problem
Inside charging jack there are some components it can damage easily.Like coil,charging filter.etc.So if you are not a tech. better to contact repairing shop.
good luck
Aug 21, 2010 | Cell Phones
Presario v2000 Laptop dead.
Its may be the problem on ur psu or ur motherboard
Jul 28, 2010 | HP Compaq Presario V2000 Notebook
Acer Aspire 4730Z laptop
if ur charger is ok then u have need to change ur motherboard
May 02, 2010 | Acer Aspire 4730-4947 Notebook
My acer aspire 1642wlmi...does not power at all...when u plug the charger it does not indicate any life in it at all...using my multimeter to check the voltage on the adapter(charger) it shows its working...
If the ac jack is soldered directly to the board you can try taking or doing it yourself change the jack out, they go bad...if the jack is connected to the board via a cable, find another cable online and change it out....try the simple first and then move on. Most of the time, the problem is the charger or the jack.
Sep 02, 2009 | Acer Aspire 1642WLMi Notebook
Power failure with compaq amarda
DC Power Jack is most like defective. Typically bad/cold solder joint. Since this is a 3 state 2 prong jack, it would be best to locate and OEM Jack and replace- simply reflowing or resoldering does not always fix it. 3 State means the battery will charge with AC on and Laptop off the laptop will work with the AC on the laptop will work with the AC off and battery charged Worse case scenario an on board fuse blown (rare) Don't forget to rate me - Why? Because if I don't know if answering helps, I'll stop posting.
Nov 23, 2006 | Compaq Armada M700 Notebook
Karbonn K9 Logo
1,950 people viewed this question
Top Karbonn Cell Phones Experts
boca
Level 1 Expert
nelson crespo
ray gallant
ray gallant
Are you a Karbonn Cell Phone Expert? Answer questions, earn points and help others
