We have problem in Power Edge R710, the display appear this alarm (Storage drive 4: slot sensor for storage, drive fault was asserted), and the indicator lamp flashing (green &amber), can you help me to solve this issue?
Sounds like you have a RAID. Take a look at the RAID management software and see if the RAID is degraded. If it is degraded you probably have a bad drive on your hands. Replace the drive and the RAID should rebuild. If it is not degraded. I would turn the server off for a sec remove all the drives and blow out the RAID carriage. I tend to do this anyway on our servers every quarter to keep the system clean and cool. Hopefully this helps.
Data Link Protocol Ethernet , Fast Ethernet , IEEE 802.11g , IEEE 802.11b
Compliant Standards IEEE 802.11b , IEEE 802.11g
Expansion / Connectivity
Expansion Slot(s) 1.0 (total) / 1.0 (free) x PC Card - SO DIMM 200-pin , 1.0 (total) / 1.0 (free) x Memory - Type II
Interfaces
1.0 x Headphones - Ethernet 10Base-T/100Base-TX - 25 pin D-Sub (DB-25) ,
1.0 x Microphone - IEEE 1284 (EPP/ECP) - 15 pin HD D-Sub (HD-15) , 1.0 x
Parallel - Output - RJ-11 , 1.0 x Network - Phone line - Mini-phone 3.5
mm , 1.0 x Display / video - S-video output - Mini-phone stereo 3.5 mm ,
1.0 x Modem - Input - RJ-45 , 1.0 x Display / video - VGA - 4 pin USB
Type A , 3.0 x Hi-Speed USB
Miscellaneous
Features Power-on password , Hard drive password , Security lock slot (cable lock sold separately)
Compliant Standards ACPI , Plug and Play
Power
Power Device External
Voltage Required AC 120/230 V ( 50/60 Hz )
Power Provided 90.0 Watt
Battery
Technology Lithium ion
Installed Qty 1.0 / 2.0 (max)
Capacity 4300.0 mAh
Operating System / Software
OS Provided Microsoft Windows XP Home Edition
Software
AOL , Drivers & Utilities , ArcSoft ShowBiz DVD , Norton Antivirus
2004 (3 months subscription) , Toshiba Custom Utilities , Microsoft
Office OneNote 2003 , Microsoft Works , AT&T WorldNet Service ,
Toshiba Touch and Launch , InterVideo WinDVD 4 , Toshiba Notebook
Maximizer , Toshiba Speech System , Toshiba ConfigFree , Adobe Acrobat
Reader
I guess it's difficult to get free ************ for your office, but you can get a much cheaper one from www.vanskeys.com, I got my key from this site and its low price surprised me a lot. You can go this site to have a try.
Your hard drive has a problem and needs to be formatted. this has happened to me twice already but not with the original hard drive that came with the ps3, I changed mine to a 500 gig drive which had the problems.
the bad news is that you have lost everything that you saved onto the drive and need to reformat and reinstall the ps3 operating system.
If you go through the system settings there is an option to format the drive. Do that. Then you need to get a USB flash drive, and follow the steps below
Download the update and save the file to a compatible storage device such as Memory Stick, Memory Stick Duo, a USB or PSP.
Before starting, use your PC to create a folder named "PS3" in the storage media or USB. In this folder, create a folder named "UPDATE" (the folder name is case sensitive and must appear in capital letters). Once the UPDATE folder is created, download and store the update for PS3 system software.
Once the update saved, remove the storage media and connect to your PS3 via the slots under the slot cover, or USB, depending on the storage medium used.
Once the storage media connected, go to Settings on the home menu of the PS3, select System Update, then update via Storage Media. Select the storage media connected to the PS3 installs the update data stored there.
Expansion Slots Total (Free)1 ( 0 ) x Processor , 2 ( 1 ) x Memory , 1 ( 1 ) x PCI Express Mini Card
Interfaces1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 6 x Hi-Speed USB - 4 pin USB Type A ( 4 in front ) , 1 x Network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x Display / video - HDMI - 19 pin HDMI Type A , 2 x Keyboard / mouse - Generic - 6 pin mini-DIN (PS/2 style) , 1 x Headphones - Mini-phone stereo 3.5 mm , 1 x Microphone - Mini-phone 3.5 mm
Printer
TypeNone
Miscellaneous
FeaturesSecurity lock slot (cable lock sold separately)
Compliant StandardsPC 2001
Power
Device TypePower adapter
Power Provided65 Watt
OS ProvidedMicrosoft Windows XP Professional
SoftwareAcer Smartboot , Google Desktop , Google Toolbar , Acer PowerSaver , Acer Client Manager , Acer QuickMigration , Adobe Acrobat Reader , Veriton ControlCenter , CyberLink PowerDVD (OEM) , Acer eRecovery Management , McAfee Internet Security Suite (Trial) , Microsoft Office Professional 2007 (60 days trial)
Manufacturer Warranty
Service & Support1 year warranty
Service & Support DetailsLimited warranty - 1 year
v\:* {behavior:url(#default#VML);}
o\:* {behavior:url(#default#VML);}
w\:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
You can
try to use the phone as a mass storage. 1.Insert
a formatted memory card into the memory card slot on the handset, located under
the battery cover 2.Navigate
to the location of the MP3 file(s) then copy to the Windows clipboard 3.Plug
the USB cable into both the handset & the PC 4.If
the Select USB Mode box appears on the phone display, select Mass Storage oIf
the Select USB Mode box doesn't appear, change the USB setting to Mass Storage oWhen
successfully connected, the handset will show the connected icon
on the top of the display 5.A new
Removable Disk box will appear on the PC's monitor, prompting "What do you
want Windows to do?" 6.Double
click on "Open folder to view files using Windows Explorer" 7.Paste
the MP3 file(s) into the phone's Sounds folder
Audio output compliant standards AC '97 , DirectSound
Audio Input None
Input Device(s)
Input device type Keyboard , TrackPoint
Telecom
Modem Fax / modem - CDC
Max transfer rate 56 Kbps
Protocols & Specifications ITU V.90
Modem features V.92 upgradable
Networking
Networking Network adapter
Networking / Wireless LAN Supported Yes
Data link protocol Ethernet , IEEE 802.11b , IEEE 802.11g , Fast Ethernet
Remote management protocol CIM , DMI 2.0
Expansion Bays None
Expansion Slots Total (Free) 1 ( 1 ) x CardBus - Type I/II/III , 2 Memory - SO DIMM 200-pin
Interfaces 2 x Hi-Speed USB - 4 pin USB Type A , 1 x Parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) , 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x Modem - Phone line - RJ-11 , 1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x Headphones - Output - Mini-phone stereo 3.5 mm , 1 x Microphone - Input - Mini-phone 3.5 mm
Miscellaneous
Features Wake on LAN , Power-on password , Hard drive password , Administrator password , Security lock slot (cable lock sold separately)
The front panel display contains seven (7) lights which provide the following information:
Power-On - Steady green glow indicates that power is being supplied to the Data
Silo chassis.
Temperature Warning - Flashing red indicates that internal operating temperature
has reached 43? C (109° F).
Blower 1 or 2 Failure - Flashing red indicates a blower has failed.
Power Supply 2 Failure - Flashing red indicates second power supply has failed.
Power Supply 1 Failure - Flashing red indicates first power supply has failed.
Mute - When switch is depressed, a steady yellow glow indicates the audible
warning sounds have been disabled. Depress switch again to enable sounds.
Reset - Depress switch to reset chassis and clear any error conditions.
The specs on the DS550 do not say anything about an F at all? Did you put the correct model number?
