Question about SanDisk Sansa m230 MP3 Player
I need to get my computer to recognise the SanDisk Sansa M230 MP3 Player. I DON'T want to download something that will play around with the entire computer. One Driver ONLY> Cam
  • rkff22 Jan 29, 2009
    can not see all the songs i previously installed.
    I want to remouve the old songs
  • 758 Answers
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Posted on Jan 29, 2009
SOURCE:
Looks like its impossible to delete music from sandisk "sansa" model m230 ,,,,, without an manual right?? thanks joe
Yeah.That's right joe.You can have the detailed manual for your SanDisk Sansa M320 by a single click on the following link. (http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf ).Things are getting too fast.Isn't it Joe?.So don't forget to rate me.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 14, 2011 | SanDisk Sansa m230 MP3 Player
How to download music to my sandisk sansa m230?
MP3 players can only play music files in mp3 file format. Music files need to be converted to mp3 file format before copying to the MP3 player. Please click on this link and follow my instruction to convert music files :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Dec 08, 2010 | SanDisk Sansa m230 MP3 Player
Will my mp3 player (sandisk sansa m230) charge
Assuming the computer puts out enough juice, yes. Not all USB ports do.
Plug it in, and the Sansa should say "Charging" if it is charging. If it doesn't, try a different USB port if possible. If your computer has ports on the front/side and on the back, the back ones are more likely to put out sufficient power.
Apr 29, 2010 | SanDisk Sansa m230 MP3 Player
Sansa m230 not syncing music files or downloading them. Process leaves the Sansa m230 with 0 files and i am finding it impossible to load new file(s) ?
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. Then add music this way and see if it is works: 1. Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer. 2. Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player. 3. Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player?s memory are displayed. 4. Open a folder containing music files that is stored in your desktop computer?s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player. 5. Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list. 6. Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Oct 01, 2009 | SanDisk Sansa m230 MP3 Player
Sync Notice
hook it up to your computer and allow windows media player to sync your mp3 player to the computer.
Apr 16, 2009 | SanDisk Sansa m230 MP3 Player
Sansa m230 won't play my PC's music
Not sure what fixed it. I formatted the player - which, of course, deleted all that was on it. I refreshed the player. and just fiddled around with it. Now the music plays and I also downloaded a couple of books onto it. Also read someof the other questions and solutions you had on your web site. Thanks for your help.
Jun 29, 2008 | SanDisk Sansa m230 MP3 Player
My sansa 250 mp3 player
the only thing that you have to do is that when they send you that message don't click yes. But you also have to go to www.sandisk.com so you can download the software for your sansa. Hope this helped find the solution for your issue!!
May 11, 2008 | SanDisk Sansa m230 MP3 Player
SanDisk Problem
Sandisk website has the software
Apr 09, 2008 | SanDisk Sansa m230 MP3 Player
Sansa m230 (512 MB) MP3 Player still not working after do what you told me
i download an update from the site that solve this to me. but in another time, mine only works when it's plugged to pc,then open the device and cut the tiny battery that have inside (CR621 or something like this) it was shorted.
Sep 07, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
66 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
