Ariel AM156JDTSZ Platinum Corner Whirlpool Bathtub - 59" x 59" x 24.02 Logo
Posted on Jan 23, 2013
I have an ariel whirlpool tub that has an E1 error problem
When i turn the power on the led screen at the top it shows E1.. and tub will not do anything..
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 16, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
393
Points
Did anyone ever find the solution I'm having the same problem
Anonymous
Level 1:
Spread the Word:
An expert who has shared 5 answers on their Facebook wall.
New Friend:
  • Contributor 52 Answers
  • Posted on Jan 31, 2013
Anonymous
Contributor
Level 1:
Spread the Word:
New Friend:
Answers
52
Questions
0
Helped
14395
Points
66
Have never heard of that error code. What brand of bathtub do you have?
Rod
www.uspartscenter.com
2answers
Can the door lock for a Whirlpool oven be fixed be
it could be. Please call lowe's or home depot or use online chat to send a phone of the broken door lock and request an in-home repair. If the part is repairable, then the home repair service will be scheduled.
Thank you.
Whirpool dishwasher ADPS 5540 shows F8 E1 after 30 minutes
turn off the water and remove the hose at the rear of the machine. Inside you will find a small wire gauze strainer. This blocks with limescale and debris from the water mains, just enough to reduce water flow below the thresholds..
E1 F8 Whirlpool dishwasher If F8 E1 or LF (too long to fill) appears in display, it means the washer is taking too long to fill. It's possible the drain hose extends more than 4.5" (114 mm) into standpipe.
Apr 5, 2021
F8 E1 Error Code for Top Load Washer - Product Help
2answers
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
How to fill an ariel bathtub
The proper way to fill the Ariel Bathtub is to turn on the faucet that is near the tub with warm to hot water to your liking. Once it is above the highest jet in the wall of the tub, if your Ariel tub is a Whirlpool model you may operate the jets.
Rod
US Parts Center
888-521-6183
E1 F1
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
3helpful
Error code
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.T$%^%ETG
2helpful
Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
2helpful
Oven has error E1 F1 will not work
F1 - E1
EEPROM checksum error
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Top Ariel Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Ariel Home Expert? Answer questions, earn points and help others
