SOURCE: 2002 Hyundai Accent lost power
Hi and welcome to FixYa,
Offhand, definitely an electrical issue. Some ideas to check, consider and/or explore:
Good luck and Thank you for using FixYa.
SOURCE: 2000 Sonata - Radio quit working
you need to go to the Hyundai service center they can reset the radio I believe this is a security feature, you may be able to call the service center to find out the procedure to reset the radio, it is the original right ?
SOURCE: ESP & ABS light comming on all the time
you should have the ESC/ABS module scanned for DTC's.
here are the 2 most likely causes.
1. low brake fluid
2. sticking/siezing brake lamp switch
at the dealership i see the brake lamp switches go bad left & right on a lot of the newer hyundai's. are your brake lights working?
SOURCE: 2002 hyundai elantra has a problem with erratic flickering dash/headlights
Sounds like you have a bad ground. If it is not that you must have a gremlin.
SOURCE: the radio is stuck on one station and won't change or turn off
try to replace it with a different CD player
