Brother Fax 2920. When an in coming fax starts to print the paper jams up inside and then the paper emerges fan folded. This happens each and every time.
THERE IS SOME THING BLOCKING THE PAPER PATH, MAY BE PAPER OR SOME THING FELL IN THE MACHINE GOOD LUCK BROTHER TECH
This is a common problem and does need a service engineer, the four fuser exit roller assemblies need replacing as they have been upgraded to address this problem.
FYI the parts cost approx
Press Menu/Set, 2, 4, 1.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
To print a report
1 Press Reports.
2 Press ? or ? to select the report you
want.
Press Menu/Set.
