Re: Taylor 433MHZ cable free thermometer won't show...
Check battery in outdoor sender and reset main unit to receive transmission of data. If nada could be that you have an issue either with the sending unit or the receiving unit of your weather station. Has happened to me a few times already so .................
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Alkaline batteries will not work below freezing in the outside temperature sensor. Buy Lithium batteries for the outside sensor unit alkaline are okay for the inside unit.
My outdoor thermometer transmitter was sending hhh instead of the current temperature. I opened it up a bit and sprayed it with compressed air (Ultra Duster or similar product) to clean the temperature sensor. It has worked fine since then.
