Everything is installed and works except for the remote start. When I attempt to arm the car, the doors lock and LED blinks correctly, then it goes into reminder mode with lights blinking and LED continuously. I only have one wire for the starter on the alarm, camry has two wires. Same for the ignition wires. The alarm system did not come with valid directions, and I cannot find them anywhere online. I am desperate for this to be fixed, car has been apart for over a week now, and wife is getting upset.
Installations of this nature are usually reserved for professionals. However, get out your installation manual. You will also need two single pulse double throw relays and some diodes. First you will need to locate the ground when running.This wire might be labeled " (-) third ignition". The first relay for the starter will be wired like so: starter wire to 86, fused 12 volts to 87, 30 out to vehicle second starter wire, 85 to ground when running. The second relay will be wired 86 to vehicle ignition, 87 to fused 12 volt, 30 out to second ignition, and 85 to ground when running.
SOURCE: 1997 Chevy Silverado Car Alarm w/remote Start
Hello m1..... Here is the link to this alarm manufacturer including manuals, etc. If this site does not answer all of your questions, click on their contact icon and speak directly with their technicians. http://www.xlsperformance.com/cars_alarm_starter.htm
Joe
Thanks for choosing Fixya!
SOURCE: I bought a SPY TWO
Well done.....
Sounds to me like you've installed it correctly.
The only thing I could recommend at this point, is to scan your vehicle's PCM for OBDII fault codes - this will immediately identify which ignition circuit/component may have been disturbed during installation.
Cheers,
