HP Officejet 6310 All-In-One InkJet Printer Logo
Posted on Jan 27, 2009
HP officejet 6310 cannot fax
Recently switched from Verison to Comcast phone service and once I did this, the fax did not work.
  • 2 more comments
  • mariacoglian Jan 27, 2009
    yes we spoke to comcast and they said it was an HP issue.
    ...more information Verison was analog and Comcast is digital... so does anyone know how to set up the fax using a digital phone service?
  • Anonymous Jan 28, 2009
    We have a cisco analog adapter for our digital lines, however, we CAN make calls to and from the fax using land and cel lines, but it will NOT connect to other fax machines whether receiving or sending.
  • Anonymous Mar 19, 2009
    Just moved to Virginia. Wife is working remotely to her job in Florida and connected the HP 6310 All-in-one but it will not Fax. Have Comcast Digital service for Internet, Cable & Phone. Equipment is recognized and installed but no Line is found when testing the Fax capability.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
713
Points
Yes, we just moved (in Michigan) and our service at the new location is Comcast, including a digital voice line. Our fax wouldn't work - no dial tone even though the telephones would work. We were with Comcast before but we must have had analog. Checking the HP6310xi user manual - troubleshooting section - (online at HP site), I noted that the manual says the fax can't send or receive over a digital line. So, that's the problem and I'm not aware of any fix to that problem, except get a new all-in-one machine or new fax machine that works over digital lines.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Jan 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1004
Points
11
Did you have fax service on the line?
How do i connect the fax for my officejet 5510. i use comcast modem for my phone. thanks.
Greetings - Your Officejet was made to fax over an old fashioned analog phone line (POTS) but you're using VOIP phone service (over the internet) which in inherently incompatible. VOIP fax works with some internet providers but apparently not comcast. But it still may be doable.
I recommend you call Comcast tech support to see if they can help you. Maybe something has changed.
There is a good discussion about this issue where some people have it working here:
http://forums13.itrc.hp.com/service/forums/questionanswer.do?admit=109447627+1299136337271+28353475&threadId=1163479
Good Luck, Mikeywaf
All of my test fax are no answer. I have the
Your cable modem is not normally a source for telephone line that the fax machine will support. If you have telephone service through Comcast, You need to contact them about proper hookup to configure your fax line.
Officejet 6310 fax does not work incoming or outgoing
Hello sir; would you take one phone hook up with this phone jack,if there have dial tone,that's means fax modern defective, if no dial tone that's means this phone jack is not active.
1helpful
HP Officejet 6310 All-In-One InkJet Printer Changed home telephone system and now I can send faxes out but cannot receive?
Hi
Check the following link
CAN SEND but CANNOT Receive
  1. Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code. To modify the fax header, use the following steps:
    1. Press the Setup button () on the product control panel.
    2. Press 4 for Basic Fax Setup, and then press 1 for Fax Header.
    3. Type personal or company information using the keypad, and then press OK.
    4. Type the phone number, including area code, for your HP fax product, and then press OK.
  2. Dial 1-888-HPFaxme and send a fax to the HP Fax Test Service.
2answers
I can not send or recieve faxes. Ran fax test
Cox Cable is pretty much the same as comcast's and vonage's services. HP fax machines have had HUGE compatibility issues with those types of services, and may be that they did something to their service that caused your fax to stop working.....
Other than that call HP and see if they have any troubleshooting or Diagnostics that you can run, but I ran in to these problems with HP faxes all the time while installing comcast phone service, never knew WHY it didn't work, just that HP doesn't work on that type of service.....at least certain models...Also maybe call COX and see if they did anything recently that could cause it to stop working....
2answers
Can no longer send/receive faxes since switching to digital phone
hi
fax does not work on digital line it only works on analog line........if u want our technician expert then contact us athttp://tinyurl.com/ldnuy2
Master Reset
I don't have a 6310 but I do have 4 printers one of which is a 5610. I never bothered w/ a reset switch because I would just turn the printer off, then unplug everying for 2min. Then I would reconnect everything back. If it doesn't work, I suggest you uninstall the software and reinstall it again. Let me know if this helps.
3helpful
3answers
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
k24674
Grand Canyon Tech
Grand Canyon Tech
