We added a new server, Intel R2308IP4LHPC, to the inside network protected by a Cisco 5505 Firewall in transparent firewall mode. This intel server cannot access the outside world, and cannot be accessed from the outside except for one of three ip assigned as management. The rest of the machines are of various age and brands, from an old VAX up to the latest HP Proliant, and they work ok. We haven't got a clue. Any input is appreciated.
SOURCE: asa 5505 firewall problem
PPPoE is not supported when failover is configured on the security appliance, or in multiple context or transparent mode. PPPoE is only supported in single, routed mode, without failover.
http://www.cisco.com/en/US/docs/security/asa/asa81/config/guide/pppoe.html
SOURCE: Pix 515E inside to outside translation problem
Dear Kiran,
What is the name assigned for isp 1 as well as isp2.
for your reference kindly find the sample configuration......
ISP 1:
interface ethernet 0 100 full
nameif outside security-lvl 0
ip address outside 203.193.129.132 255.255.255.240.
nat (inisde) 1 (local network)
global (outside) 1 203.193.129.133
route outside 0 0 203.193.129.129.1.
regards,
mani.S
SOURCE: Cisco ASA 5505 Firewall
1. Change your PCs default gateway to your firewalls' internal IP
2. configure the nameservers on your ASA
Then internet will work fine.
SOURCE: how will block yahoo.com using cisco asa 5505
Hello there, you need to check this out
Regards
SOURCE: how to internet site block in asa 5505 cisco
This should tell you everything you need to know -
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080940e04.shtml
Hope I helped
Dr Reed
Forgot to mention we are using Debian 6 on the intel server. However we think it is some kind of hardware problem.
This case could be closed. The problem disappeared once the firewall was rebooted.
