SOURCE: Toshiba e-Studio 350 FAX Communication error
Are you still receiving faxes although you are unable to send? Or is it no send & no receive? When you hook a phone up are you able to connect with a # dialed from that phone. It's possible that the problem is the copiers NCU board- but it's rare that they fail & even more rare that it loses just the send portion. You'll want to be absolutly sure that it's not the phone line. If you are positive that the problem is not the phone line - try turning the machine off & unplugging the power cord for 30 minutes. Occasionally the NCU card will lock up & not function properly. Unplugging the machine for 30 minutes has worked for me in the past.
SOURCE: e-studio 163 coppier - I cannot connect it to pc
hi frnd do one thing
go to printers and faxes
select toshiba e-163,
right click
select properties
select port
select com 3
try to give print
OR
select com 4
and give print i may be ok.
pls up date me
regards
san
SOURCE: toshiba e studio 166 like printer dont work
connect the copier to computer through USB cable, turn it on, then re-install software it will recongnize the port and machine itself.
SOURCE: Print driver for Toshiba E-Studio 3511 Copier/Printer for Window
You can go to http://copiers.toshiba.com and download it.
SOURCE: Driver for Toshiba e-Studio 16S printing for Win 7 computer
pls go doenload page of toshiba. then u can easyly find out the driver for win7.
