Answer machine picks up after 2 rings how can I change the # of rings
SOURCE: setting the number of rings to answer
Press "Mute" to setup handset, select "Ring to answer", here are 1,2,3,5,6,L choice. you can change to 3.
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
SOURCE: GE Telephone answering machine will not work
298976e2-a owners manual,
i have same problem,
sorry if my english not the best.
i "paste and copy"
We have the answering machine set to 4 rings. When people call, the machine picks up on the 4th ring, it beeps, then cuts off. No recorded message. No message is recorded, the call is disconnected. What do we do?
send me email.
[email protected]>>>Canada
