How to unlock my sony XAV-77 monitor after changing DVD player and unplugging The power. Code for unlocking has been lost a long time ago
Hi try out this link...
http://esupport.sony.com/perl/model-docu...
Master code can only be used with a remote....... press enter then 5415 then enter agin it wont show on screen so give a sec or two afer each number you enter worked fine on mines
Hi..At first try with thw code 0000 to unlock
the monitor.If u still continue with this problem
look in the product website which will provide
you with the sokution.It is available on the net.
Just enter your product and the model number
it will list you with the various options.From that
u can select the one which you are looking for.
check this out..
thank u..
Need to know what vehicle that's in and the serial number as well
Please try these codes 15898,11034..
Good luck..
Hi sir,
here is a smart way,,,,,in the password screen enter the following master password 4357.
after using master password create a new password now u can unlock it........shore
please post back the comment...thank u
see here for further info on thios service manual http://www.scribd.com/doc/2951756/Sony-K...
Sir,
I think if you entered more than 5 times it will not unlock by yourself. Only u contact manufactuer for unlock the device. Also contact this email for more help
[email protected]
thanks
good luck
You need to go to your nearest service center. They will unlock it for you.
Welcome to Fixya! You will need to Contact Sony Either Via the Web or their Customer Service Line to get the Manual Reset Code for this Model. Each Sony has a Different Unlock code so the Master may not work on Certain Models as is the Problem with yours. Please Rate My Response! Thanks!
The code will be present in the manual.
If you dont have manual you need to contact dealer to get the code .
There is no other way to get the unlock code .
The code is five numbers, but there is no fixed code, your pin was set and assigned when you purchased the unit.
If you have lost the pin code the only way out is contacting the seller, that can access the code associate with your unit, the ony alternative is trying all 99999 codes.
If nothing had worked yet, use the service below, they can calculate the code by connecting to a database, Service costs a small fee:
Online Radio Decoding for Lost Radio Codes
Decode your car radio online
Also try the key combinations in here, they can unlock some Sony model and bypass the code request.
SONY DVD monitor XAV-77 requesting lost PIN CODE. The manual has been lost. Sony answer is to take it to their repair shop and be charged for product support. Apparently its a serious of command keys from the remote and the unit itself. These series of command will unlock or clear the internal memory of the unit and make way for another, they are just not willing to give it. If I could get intructions on what keys to press that would be great.
Thanks
Hi
I tried the master password 4357, and that didn't work, it came up with "Code Error" message after i pressed enter. Awaiting further instructions.
Thanks
Hi
As far as I can see it, its only a four digit code.
Thank you
Hi Everyone
I'm still unable to unlock my SONY XAV-77 in-dash monitor(Car Audio) after changing DVD player and unplugging The power. Code for unlocking has been lost a long time ago. Its a Four Digit Master Pin to Unlock the unit.
I've tried the master password 4357, and that didn't work, it came up with "Code Error" message after i pressed enter.
I've also tried 1589,5898, 1103, and 1034 from this five digit pin a member forwarded (15898,11034) Please Help.
Thank You
Hi
This unit has only got four segments to enter the pin. If you move forward one to the next digit after enter the first four digits it just comes back to the first one. I have also tried 0000, 1111, 2222, 3's and so forth all the way to 9999 and it still wont open. The original installer 3 years ago don't keep records of such pins we've tried already, and Sony won't give the product support necessary. Awaiting further instructions.
Thanks
Hi Everyone
Thank You
Hi
Its in a 2004 Honda Integra, as for the serial number its has been installed for 3 years. I'll have a look. Is there a master code to unlock?
Cheers
Hi Everyone
Thank You
Sony Australia Product support is not willing to hand out the code for free. They've adviced me to take it to their repair shop to be charged $80 to reset the unit. The code is a four digit pin and even if I press the reset button on the unit it still request the code or reset pin. The pin was in the original manual which has been misplaced. Does anyone know what the master reset pin is?
Thanks
Hi
I'm unable to unlock my SONY XAV-77 in-dash monitor(Car Audio) after
lost a long time ago along with the manual.
I've downloaded the user manual and I've tried to reset the unit but its still
requesting the CODE. Its a Four Digit Master Pin to Unlock the unit.
Its installed in a 2004 Honda Integra.
Sony's answer is to take it to their repair shop and be charged for product
support or they are just not willing to give it.
If I could get instructions on what keys or the master code that would be great.
I've tried the password 4357 as suggested by a forum member. I've tried the obvious
0000 1111 through to 9999, and non of them worked, it came up with
"Code Error" message after I pressed enter.
At this stage I need a master pin to overwrite the pin choosen during instalation
and make way for another.
Thanks
Hi
Thanks
