The dryer runs and heats but the clothes don't get dry. The dryer has stopped and restarted itself in the past and now I am getting the code AF. Checked for lint build up in exhaust and found none but there is no air flow out of the dryer. Blower fan doesn't seem to be turning.
SOURCE: gas dryer/ whirlpool
Hi my Whirlpool dryer is not generating any heat and makes a
grind like noise then goes away after a min. model# LGR4634EQ3
Type # 121-00 anyhelp please thanks
Brian
SOURCE: Dryer not generating heat and drying clothes...
Dear customer,
We recommend you to do the following checks when your dryer isnt generating heat..
Thank you.
SOURCE: my dryer has stopped heating i checked the exhaust
You have a bad thermal fuse and cycling thermostat. You can buy them ina a kit. When the cycling thermostat goes out the dryer cycles on the thermal fuse (High limit) until it goes out causing the dryer to not heat. You can take the back off and look for them. There are two different thermal fuses. One type is round on and looks like other pieces in the back, only smaller around. About the size of a dime. The other is 1/2" wide and 2" long. Both have two wires. You can test and see by unplugging the machine, connecting the two wires going to the piece together. Tape them together so they touch no metal. Now plug machine in and try. DO NOT OPERATE MACHINE WITH PIECE BYPASSED. THIS IS FOR TESTING ONLY.
Please rate solution if helpful.
