Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Wont stay on.
It will not boot up. It will come on for 3 sec. and then the screen will go blank.when you try to turn it back on it will come on and go blank again. when you plug it in to the computer it shows up as charging but wont come on .please help me fix it
  • 758 Answers
Please check to make sure the hold button at the very top is not activated...that would cause it to shut down..
I hope that helps
Please rate accordingly
Thank you
Computerrep
Posted on Jan 29, 2009
SOURCE:
My kobo wont turn on
When you slide the switch back, you should wait 3 sec and then let it go the green light will come on - if screen stays blank re- syncing you e-reader to your computor.
Apr 25, 2014 | iPhone Apps
My Asus laptop's screen is blank and stays blank.
You might try a hard boot, hold power button 5 sec. then as it reboots use one of the function keys to get into the bios. Usually F2 or F8 or F12. Start in safe mode then check you resolution setting and make sure you video card drivers are up to date. Good luck.
Apr 07, 2013 | Computers & Internet
When I'm told the system was not turned off correctly press ok then the screen stays blank
You corrupted your settings. Turn on the Ps3 let it power cycle, once you get to the blank screen hold down the power button until it beeps 3 times (about 25 secs) Your ps3 will shut off( note: if you have HDMI only, plug in your RCA connections as this will reset your ps3 display to analog) once you are back at xmb, plug in your HDMI and go to display settings and select HDMI. Always let your PS3 do its thing before shutting it down, its equivalent to unplugging your computer instead of logging off correctly.
Jul 06, 2012 | Sony Playstation 3 (PS3) Console
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Aug 25, 2011 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
HP nx7010 - Blank Screen - wont load.
This looks like it can't recognize the hard disk or it's empty - no OS. To check that it's not a hardware fault just boot from a Linux Live-CD like http://pclinuxos.com/
If the hard disk is there and with all the data apparently intact then most likely the MBR was corrupted, fix it.
Jan 13, 2010 | HP Compaq nx7010 Notebook
My Dell Inspiron 6000 (which I think I bought in
Have you tried this:
1. After removing the battery
2. Press and hold the power button for at least 10 sec.
3. Put back the battery
4. Turn it on
if this doesnt work, there could be a problem with your operating system. Try accessing safe mode if you can login .TAP F8 continously on the dell logo screen, and it will open advance boot options. (Just select safe mode) If safe mode boots properly try running system restore to restore it back to the previous date where your computer is still booting to windows. Hope this helps
Dec 08, 2009 | Dell Inspiron 6000 Notebook
Touch pro screen blank
first try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then then go to www.htc.com and upgrade ur ROM
Pls rate me FIXYA if it helps
Mar 14, 2009 | HTC Touch P3450 Smartphone
PS3 wont load any games
try holding the power button down for 5 sec this will do a manual reset, if that doest work make sure you video cables or hdmi is tight
Mar 01, 2009 | Sony PlayStation® 3 (60 GB) Console
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
55 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
