No because it is too dangerous. When you go into Airplane Mode, you literally turn everything off! Airplane Mode is only for being on an airplane. If you are using it a lot whilst not flying, you are not using it correctly.
I have this revel tortilla maker with nonstick plates But when I started making tortilla it sticks to surface and very hard to clean it I paid $50 bought it from Patel brothers in New York Can you guide me what should I do?
1. Press and Hold the Power button for 2 Seconds. A menu pops up. On that list, you will see "Airplane Mode" (under which should state "Airplane mode is ON").
2. Now tap "Airplane Mode" to switch it Off. If you press the power button again after a few seconds, it should now say "Airplane Mode is OFF". This is how you want to leave it. Done.
Airplane Mode (Motorola CLIQâ„¢ with MOTOBLURâ„¢) NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active. To turn Airplane mode on or off, refer to the following: ---------------------------------------
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps: 1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps: 1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
There is a cheap plastic retainer on the end of the rod that holds it to the handle. Get a Wheel color from a RC airplane hobby shop and use it to hold the rod on the handle. Works better than the original clip. You don't need to take the door apart for this, you can usually reach the rod after removing the interior latch handle.
