Dishwashers Logo
Posted on Jan 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Door open light stays on when door shut.
The door light stays on when the door is shut and the buttons beep, but wont work. the light says door open.
model kudv24se
  • jayandlaurie Jan 27, 2009
    switch seems to work fine. I don't believe the problem is in the switch because the switch will turn off the light when I press it, but will come back on when I let go. It seem to work the opposite way.
    NO THE MACHINE WONT WORK WHEN I HOLD THE SWITCH AND PRESS WASH. THE BUTTONS WILL ONLY BEEP WHEN THE DOOR OPEN BUTTON IS LIT UP. THE BUTTONS WILL ONLY BEEP THEY WONT DO ANYTHING ELSE. IF THE DOOR OPEN LITE GOES OUT WHEN I PRESS THE SWITCH THEN THE CONTROL PANEL WONT BEEP.
Anonymous
Level 2:
  • Expert 65 Answers
  • Posted on Jan 27, 2009
Anonymous
Expert
Level 2:
Answers
65
Questions
0
Helped
31642
Points
156
Sounds like a faulty door switch not sensing that the door is shut. test the switches for continuity to determine the faulty switch
  • Anonymous Jan 27, 2009
    does the machine function when you hold in on the switch and the light goes off
    it sounds like maybe the control is having an issue sensing the door switches. disconnect power and see if you can see any obvious damage on the control circuitry. good luck
Why is my Frigidaire Professional all refrigerator beeping continuously?
If the door seal is that bad that it is letting all of the cold out. Put the duct tape on the left, right and bottom edges. Just enough pressure to seal.
Top part of my frige wont stop beeping
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
2answers
GE refrigerator constant irregular beeping
It looked like your model does NOT have an external ice/water control panel which has caused beeping problems on some models.
For your model I would try the following....
Door Alarm
The main cause of a beeping GE unit is an open refrigerator door. Some models are equipped with an internal door alarm, which trips when the door remains open for 3 minutes or longer.
One way to check this .... put your smartphone in the refrigerator on video mode and close the door. The light should go off with the door shut. If the video shows that the light stayed on when the door was closed ... then it reinforces that something is wrong with the switch/alarm. Repeat video for the freezer.
Door Seal
If beeping persists after the freezer or refrigerator door is closed, the door seals may be blocked or so dirty that the internal door alarm is tripped. The seals can be cleaned with a soft cloth and warm, soapy water. Also, an item inside the refrigerator may be preventing the door from fully closing.
Cooling System
Reactivating the refrigerator's cooling system includes a beeping noise. When the refrigerator is off, the "Off/Off" light appears on the door display. When the "Adjust Freezer" and "Energy Saver" buttons are held down for approximately 3 seconds at the same time the beep sounds and the "Off/Off" indicator disappears. Hold the "Ice Off" and "Freezer" buttons to activate the cooling system inside of the fresh food compartment. A beep signals the system is activated. The beeping should stop after the cooling system turns on. If it fails to stop, try unplugging the power cord to reset the connection.
Power
The GE's internal door alarm can get stuck. Try unplugging the refrigerator for about 10 seconds and then plug it back in. If the beeping continues, the internal door alarm might be broken or defective. Contact the manufacturer or a technician for further assistance. One way to check this .... put your smartphone in the refrigerator on video and close the door. The light should go off with the door shut. If the video shows that the light stayed on when the door was closed ... then it reinforces that something is wrong with the switch/alarm.
Good luck on your troubleshooting!
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 • LG Dryers
2helpful
3helpful
I have a samsung side by side fridge freezer model SRS539HW, the alarm keeps beeping every minute to say the doors are open however they are closed. If I manually pust the door closer button it will...
Solved beeping problem.........Samsung SRS539HW . Have one of these and it is 6 years old. I had to replace the bottom hinge on the fridge side(right). Easy job but now constant beeping as if door is open, and light is intermittent. Found that there is considerable wear on the cable through top hinge of door and one of the wires from a magnetic reed switch in door had broken. I discovered this by shorting the two fine wires (white and pink/white) going to internals of fridge.No more beeping due to door opening and light now working correctly. Of course I no longer get a beep for a valid door open to long but cheaper than getting a refridgerator expert in.
My Samsung Cool' n Cool Fridge Freezer it wont stop beeping. The doors are both shut and the appliance is switched on. I have accidently broken the little plastic mechanisim that opens and closes upon...
Hello, it needs to be reset, There two reset buttons one for the frig/frez and one for the filter--drinking water/ice maker. GB...stewbison
1helpful
My kenmore elite 106.59966803 beeps every two minutes. Doors are shut and the unit seems to be working fine. Any suggestions?
if the refrigerator is beeping -- then this is a sign that the door switch is not working properly,loose or broken.
to stop the beeping --- press and hold the "lock/alarm" button on the control panel until the indicator light turns off. ( this turns off the 'doors open' alarm ) --- now if you get the door switch fixed and you want to turn the 'door open' alarm back on, then press and hold the " lock/alarm " button again until the indicator light come back on.
c...
Why does the door open light stay on & beep on my 2002 lexus rx300? All the doors are shut.
sounds like the push button thats on the door jam in the front left or right door is stuck or bad
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
