Question about Leviton 1755 Triple Rocker Switch Decora
Broan 100hl, I have heater but light and fan do not work. I have 2 12/2s running to the ceiling for the unit.
I am replacing an older Beoan unit that had heat, fan & light. When I wired the new one have only heat with no light or fan.
2 Suggested Answers
SOURCE:
cool78259
  • 228 Answers
SOURCE: I have a 12/2 (black/white/ground)
The switch that you have works like 3 seperate switches. most of these switches will have gold screws
on one side and silver screws on the other side, lets say that the left is gold and the right is silver, and
the switch may also have a green screw for ground. your 12/2 with ground is your main hot, you may
want to mark it with a piece of tape, so you know it's the incoming hot. the ground off your hot will tie,
to the green screw on switch and continue and tie to your vent light which should also have a ground
the white coming off the hot is your neutral, it will go straight to your white or whites on your heater.
the black hot wire at your switch will go to each gold terminal on one side of the switch,there are two
ways you can do this, go to one side and just run a jumper, or put one wire on each gold screw and
tie in to your hot-black wire with a wire nut. now for the switch legs, you will need to run from your, switch
to your heater either another pair of 12/2s or a 12/3, each side of the switch that has one silver screw,
it's easier with a 12/3 normally a 12/3 will have a red,black,white,and ground.
top switch red to red on heater,black to black on light and the white blue on the vent,so from your switch
to the heater you would have to run a12/2 you would not use the black only the white and ground.
remember the white-neutral coming from the switch will be tied to all the whites at the vent,light,heater
except for the 10/3. the 10/3 is used stricktly for the switch legs. good luck!
Posted on Jul 10, 2011
I bought new heater motor for a Broan 100hl how do you change it
ring or email the company for this information boran
Dec 26, 2015 | Dryers
I have a 12/2 (black/white/ground) power source to the leviton 1755 switch. And, I have two (2) 12/2's going to a Broan 100hl (vent, light, heater). Please help wiring switch and Broan; on...
Jul 09, 2011 | Leviton 1755 Triple Rocker Switch Decora
We have a Broan/Nutone 763RLN Ceiling Fan/Light in need of cleani
The grille is held in place by the reflector. The reflector is hidden by the the lens. The first step is to remove the lens, then you will remove the light bulb. You will see one wing nut above the light socket. If you unscrew that the reflector and the grille should come down. The replacement motor assembly for the 763 RLN is the S0503B000, if you are looking for a little more power you could also purchase the S0504B000
http://bit.ly/ax4Upk
Jul 12, 2010 | Broan-NuTone N-763RLN Combination Light...
Nutone, Model QTXN 100HL-A 1500 Watt Does not heat. Electrician said it was the heater part that has "6260 Eichen 04" on it. He said it was the diode. I would like to order the small part.This is a...
The "diode" that your electrician mentioned is actually a one shot thermal fuse.
You can either go to the Nutone website for parts, or remove the thermal fuse, extract the info written on it and buy a replacement. Mine was a 100C 10A thermal fuse. I got mine from DigiKey.
Mar 29, 2010 | Broan-NuTone Heating & Cooling
How do you access the light on a broan fan/heater/light? This is a ceiling unit in a bathroom. It is a vent fan/heater/light combo.
Gently pull down, work it down slowly these tend to get dry over time and crack, If you do not see any exposed screws it is the basic pull down type. Not to insult your knowledge but make sure the fan is not on when you do this because the blades will be exposed.
Oct 09, 2009 | Dryers
I have a thermador bathroom ceiling heater fan. Where can I get a replacement?
Amazon.com: bathroom ceiling heater Broan Product Detail
If you have the old Thermador ceiling type of heater that must be mounted on the ceiling surface there aren't many choices. Only the Broan-Nutone 154 & 157 models. The 154 @ $37 didn't seem to last too long but it's 1/3 the price of the radiant 157 model at about $100+ dollars. The radiant model may last longer
Sep 02, 2009 | Heating & Cooling
Older Nutone bath- fan/light/heater Model #9111. Light works, fan and heater do not. Must I replace the entire unit.
Most of the time is is cheeper and less time consuming to replace the unit than to find what happen to it and then order parts to repair it.
Aug 28, 2009 | Broan-NuTone (8663RP) Ceiling Fan
Leviton 1755 Triple Rocker Switch Decora Logo
74 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
boomanfoo
Level 1 Expert
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
