The only way possible to see if the touch
pads are working is to test the voltage of the control pads when it contacts.
The input of the Microprocessor should be checked for the pad control impulse
to come in. If there is no trigger voltage to the mP this can be the control
pad problem.
The mP must be checked for the working voltage and also the frequency
oscillation at the crystal leads. If so the mP is working with a suspected
control pads which are not able to set the program or timing.
There is no way but to remove the sticker pad and replace, One difficult way to
have a chance is to remove the carbon sticker pads and check continuity , You
can use a carbon pen to line the tracks so that the multi-meter reads a
continuity. With this you can have a temporary fix. Use a dryer to warm carefully to dispere any moisture but if the pads are worn you need to replace.
