I suspect that track for the choo-choo model is compatible with what you are looking for (but that doesn't seem to be available at present either. You might try ebay, but be careful to check that you are buying exactly what you need.
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
hi did you find the instructions, i have the same problem, have no instructions and trying to put it together by looking at a picture. if you have the instructions could you please try and email me a copy if it is at all possible. My email address is [email protected]
I would check the battery voltage with a multimeter if possible. Battery should read at least 6 volts. Most likely the battery is too old to take a charge if it’s been sitting unused since 2006. I’d replace the battery first and then go from there.
well youlle realy need to buy the batteries that could fit and move into the toy you bought. also if the battery you used dindt work. maybe you should try a medium sized battery.
Try searchig E-Bay I normally manage to find any type of battery I have needed. If not research it on GOOGLE you will be able to find lots of suppliers for batteries. I hope this helps.
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
scroll down the images till you see the set that they have. click on it when the page opens look for instructions... click on that it should have them. note i did see at least one recall notice so make sure that doesn't involve the set you have
