I have ER-5215 M sam 4s electronic cash register. As soon as I turned it on it gives me a message of sequence error warning.Please help me to fix it?
SOURCE: cash register
try this
Do this :
key to program,
200 subtotal
press plu button ( or scan product)
type in price ( without decimal point)
press x/time
do next item or press cash to finish
SOURCE: e1 error message on a
Hi. Youv'e turned the key before you finished in another mode. Turn the key to each mode, and press clear, then try it back in reg. If that doesn't work, press CASh in each mode, or SUBTOTAL in each mode.
Mark
SOURCE: Reprogram Sales Tax
http://www.langsystems.com/html/ecrs_and_pos_-_Tax%20GST%20programming.html
http://www.ccrpos.com/Support/Sharp%20Tax%20Programs.htm
I'm not familiar with that cash register... be that as it may i've found a couple links (above) that may be of assistance to you.
Robert
SOURCE: sharp cash register displays error message E3.2
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
You need to logon as there is no operator assigned to it.
Press 1 then press CLK# or CASH# button.
-WN
SOURCE: sharp cash register (er-a470) won't turn on.
If the machine is dead, then you probably have a bad battery. It should be changed every 3 to 5 years by the dealer. If it has been left too long, then this is a common symptom and the machine loses all programming. Otherwise, you may have a faulty power supply or mode lock unit. It sounds like you need to see a dealer about it.
If anyone is looking for a Sharp ER-A470 manual, see here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp6.php
Many more available at
