I have decalcified and run hot water cycle. After about a week, flow of coffee is slowing down again. Decalcify is still showing up on display. System seems clogged. Is there any way to clear this without sending it in?
SOURCE: Declcification Program not working
Call Capresso co. at 1-800-220-5701. I had a problem and I received excellent help, a step by step walk -through which got my machine back to service. Great machine! Great help!
SOURCE: I am having trouble starting the decalcify
Had the same problem, i noticedt that there is a procedure to run decalcify anytime in the instructions book.
Turn off the machine, press Rinse button until it says Empty Tray then go go Step 2 in the instructions.
SOURCE: WATER LEAKS BOTTOM OF UNIT WHEN IS MAKING COFFEE
Below are solutions for a leaking coffee maker and how to decalcify the machine?
Tools and Materials needed to fix this problem are as:
* White Vinegar
* Fresh Water
* Volt-ohm Meter
* Screwdriver
Step 1 - Clean
If your coffee maker seems to be clogged, try cleaning it with a mixture of white vinegar and water. Assuming that your coffee maker has a 12 cup capacity you will want to use 11 cups of vinegar and 1 cup of water. Fill the coffee pot to the 11 cup mark with vinegar and then fill it to the 12 cup mark with water.
Pour this mixture into the reservoir and turn on the coffee maker, allowing it to run through a brewing cycle as if you were making a pot of coffee. By doing this you will dissolve any build up in your coffee maker. If the coffee maker is leaking because the pump is clogged, then this might clear the clog and stop the leaking. If it has been a while since you last cleaned your coffee maker, you may need to run the vinegar through more than one cleaning cycle to dissolve all of the buildup.
Step 2 - Pump Valve
Unplug the coffee maker and examine the pump valve. If the pump valve is broken or has a clog, then the water will not be able to rise up and flow through the fill tube. When the coffee maker is turned on, the water needs to go someplace. If it cannot flow through the fill tube, then it may leak onto the countertop. If the pump in your coffee maker is sealed, you will need to replace the whole pump. If the pump is not sealed you should check it to ensure it is not clogged with coffee grounds or mineral deposits.
Step 3 - Brew Switch
Examine the brewing switch to ensure that is working. To get to the brewing switch, remove the base plate. Next, you will need to test the switch with your volt-ohm meter. Touch the tester to the RX1 scale. If it reads 0 ohms then you will know that the switch works fine. If it gives you a number other than 0 then it is time to replace the switch.
Step 4 - Tube Connectors
If the coffee maker is leaking or sputtering then you should take a look at the tube connectors. Many times, a leaky coffee maker is caused by faulty tube connectors. If you find the leak is in an elbow, clean the surfaces before you replace it. If the tube connector leaks, replace both the tube and the elbow so that you can be sure the pieces will both fit together properly.
To decalcify, you will be needing a : decalcifying cleaner and A container large enough to hold the same quantity of liquid as your water reservoir
1) Remove the machine's water reservoir.
2) Empty all liquid from the reservoir.
3) Fill the reservoir with warm water.
4) Add one packet of the recommended cleaner to the full reservoir and stir until the cleaner is dissolved.
5) Return the water reservoir to the machine.
6) Turn the machine on.
7) Set the large container underneath the steam wand.
8) Set up your machine so that hot water -NOT steam-will be emitted from the steam wand when the steam valve is opened.
9) Open the steam valve according to the manufacturer's instructions.
10) After all of the decalcifying solution has drained into the large container (within a few minutes this will occur), remove it and discard the liquid that has been collected.
11) Rinse the water reservoir thoroughly and then fill it with the type of water you usually use for brewing.
12) Return the water reservoir to its normal position.
13) Using only water repeat steps 7 through 9 until the water reservoir is empty again.
I hope the above helps....
Good luck.
