Does you notebook shows any connection information after connect to tv. If not you need to install. If this didn't work you have to change VGA cable. If not your notebook doesnot supports the tv
SOURCE: Connect laptop to TV
the 3.5 mm-composite cable will go from your headphone jack on the left side of your laptop out to your TV. The S-Video will go from the back of your laptop to your TV. Unfortunately your samsung doesn't have an S-Video though there are converters you can get to downgrade from s-video to composite. Your toshiba though should definetly have an s-video.
If you need anything else let me know. I hope you find this worth of a Fixya rating.
Thanks,
Lee
SOURCE: Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
SOURCE: i need a driver for VGA Adapter to TV S-Video RCA
You can download your VGA adapter from www.sofpedia.com, once on the site you can type your device name and driver required on the search field.
Hope this helped.
Kind Regards
SOURCE: I just upgrade to Window 7, to my ACER AspireOne
You will need to contact acer and see if they have Video drivers that are compatible with windows 7.
SOURCE: want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
